nc30 engine rattle !!! advice needed
mirax
PostPosted: 21:46 - 03 Oct 2005    Post subject: nc30 engine rattle !!! advice needed Reply with quote
hiya my engine seems to be rattling on my nc30, it seems to be coming from the rear left cylinder, could this be the valve shims? if so what problems could this cause ?? Confused
mr.z
PostPosted: 23:48 - 03 Oct 2005    Post subject: Reply with quote
Could be loads of things, you can use a long screwdriver to have a listen...
Shims or tappets is possible (what was it last done?) if this is the noise then its SERIOUS problems if you ignore it (engine rebuild + lots of money sort of problem)
You could take it to ahonda dealership and ask them what they thing it is, needs checking out really Sad
DucatiEVO
PostPosted: 23:55 - 03 Oct 2005    Post subject: Reply with quote
If it's a rebuild that's needed you'll prolly find it cheaper to buy a replacement engine instead. Think a full gasket set alone is around the £200 from Honda. Shocked
I ended up replacing my engine as my old one developed a bottom end rattle.
aKa: Ducky
Jamie_ducati
PostPosted: 19:12 - 04 Oct 2005    Post subject: Reply with quote
Valves are adjusted on these by means of replacing the shims with different sizes. Hondas rarely need these done in my experience.
If you leave a valve loose, there is a danger it could foul the piston which means game over. Get the engine checked over!
Jamie
Time for eDUCATIon
mirax
PostPosted: 20:18 - 04 Oct 2005    Post subject: Reply with quote
used the screw driver trick on the cylinders and they seem to be ok but still cant seem to locate the noise heres a vid to see what you guys think sorry about the quality it here done off my phone.
:note you need quick time to play
mirax
PostPosted: 20:43 - 04 Oct 2005    Post subject: Reply with quote
heres another vid
The last post was made 21 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 47.92 Kb
