De-restricting my GPZ 500
biker-dj
PostPosted: 16:38 - 05 Oct 2005    Post subject: De-restricting my GPZ 500 Reply with quote
Time is nearly nigh Wink for those lovely de restricting washers to depart my Kwak GPZ 500S, could anyone give me a detailed account of how to take them out or direct me to a website that might show me how to do it, possibly even with pictures, I've looked in the Haynes manual - lol Laughing . Be grateful for any advice.
Ride with the music!
RickHolt
PostPosted: 17:05 - 05 Oct 2005    Post subject: Reply with quote
Just infront of the carbs there are two rubber tubes. The washers are in there. Follow the instructions in the haynes manual to take out the carbs, that's probably the easiest way. You can do it without removing the carbs but it's a bit of a pain to get the tubes off and on.
iCraig
PostPosted: 18:28 - 05 Oct 2005    Post subject: Reply with quote
Bring it to me and I'll derestrict it for you for free. Wink
I know the GPZ500S like the back of my hand so it'll be a piece of piss for me!
biker-dj
PostPosted: 19:17 - 05 Oct 2005    Post subject: Reply with quote
Thats very kind of you, where are you based??
PostPosted: 19:54 - 05 Oct 2005    Post subject: Reply with quote
press https://www.bikechatforums.com/templates/standard/images/lang_english/icon_profile.gif
There is a map. (looks like he is quite a distance from you)
Once you have them out, hang on to your hat the first time it hits 7,500rpm Wink
veeeffarr
PostPosted: 19:58 - 05 Oct 2005    Post subject: Reply with quote
I want a GPZ Sad Sounds perfect for me!
Would I be able to do a 250 mile trip (One way) on this bike comfortably?
Sorry to hijack your post mate! Smile
biker-dj
PostPosted: 20:40 - 05 Oct 2005    Post subject: Reply with quote
Thats ok, I am very impressed with my GPZ, very comfortable although the most I've ever done is a 70 mile journey non stop but still felt fresh and no aches. Obviously mines restricted at the moment but it's still very quick and reported top speed without restrictors is 124 mph appx. I'd like to move up to a ZX6R one day just the finances holding me back at the mo Sad
biker-dj
PostPosted: 20:45 - 05 Oct 2005    Post subject: Reply with quote
I've just checked Craig's profile and you're right he is a bit of a way for me. I'll just have to keep studying the Haynes manual.
It's hard to imagine it going much quicker - sounds like I'm in for a treat when them restrictors come out - roll on 7500 rpm. Very Happy
PostPosted: 21:24 - 05 Oct 2005    Post subject: Reply with quote
No worries. I regularly did that on a Friday night after work to get up into the Highlands for a weekend rideout with the club.
Silloth to Glencoe is 205 miles.
instigator
PostPosted: 23:39 - 05 Oct 2005    Post subject: Reply with quote
For the er5 when I had to take mine out.
https://clubs.wanadoo.co.uk/vault/kawasakier5/RestrictionDe-restriction.doc
iCraig
PostPosted: 00:15 - 06 Oct 2005    Post subject: Reply with quote
If need be I can help you even being this far away.*
Removing bits from your bike might seem daunting but its very easy, like a jigsaw puzzle.
First remove the seat and unscrew both rear side panels (check the haynes manual on how to do this as I owned an earlier A Series and the later ones differ slightly).
Once removed then, unbolt the single bolt at the bottom of the tank where the seat was.
Once you've done this then, remove the screws from under the top fairing that are attached to the tank (if applicable on later bikes).
Then lift the tank up from the back and remove both the fuel line and vacuum pipes.
Then left the tank free and place in a safe place where it won't be scratched.
Now take the metal piece off where the tank bolt attached to usually held on by 4 bolts.
Now you have the carbs at your disposal!
Next slacken the throttle cables off at the handle bar end and loosen the bolts at the carb end and gently prize them out of their holders.
Also unscrew the choke cable which is attached to the right hand carb and remove it from the choke assembly.
Now the hardest bit if you still following this!
Next unscrew the screws to the jubilee clips on the front of the black piping the goes from the carbs to the engine (the ones closest to the carbs).
Once you've done this then get a screw driver and on the other side of the carbs pull back the springs holding the airbox rubber on to the other side of the carbs.
At this point the carbs are free of being held by anything, so now pull them up from the rear and wiggle them up and eventually they should free themselves so now pull them up and clear from the bike.
The actual whereabout of the restrictor washers I am unsure of as my GPZ's were never restricted but I am sure they should be pretty noticable being 2 large washers, maybe in the carb manifold tubes going into the engine?*
If you want anymore help or need a chat to ask something I am happy to help.
Add me as a friend in your profile and you can see my mobile number in there or just PM me.
biker-dj
PostPosted: 01:03 - 06 Oct 2005    Post subject: Reply with quote
Thanks ever so much for that Craig, I have a Haynes manual at my disposal as well so with that and your detailed breakdown of what to do I am sure I can crack it. Thanks again and heres to those un-restricted rpms Thumbs Up
PostPosted: 01:35 - 06 Oct 2005    Post subject: Reply with quote
What he failed to mention is that getting the rubbers back on again is a complete bastard! Especially the ones between the carbs and the airbox.
The easiest way to do it is to get everything more or less on, you will probably find no matter what you do, the airbox rubber gets caught inside the end of the carb. Now remove the top of the airbox and the air filter and find yourself a small child (10 years or younger). Tell them you will buy them a big bag of sweets if they will just put their (small enough to fit) hand in through the airbox and push the rubber bit out round the neck of the carb with their fingers.
I would strongly recommend only doing this using a child who is either a close relation or having first sought their parents permission.
I do not have access to a small child and spent an hour last night doing this exact task.
veeeffarr
PostPosted: 02:04 - 06 Oct 2005    Post subject: Reply with quote
It's worth mentioning you could also employ the help of someone who possesses a beadle esque "little wanking hand" to do the job as well.
instigator
PostPosted: 15:36 - 06 Oct 2005    Post subject: Reply with quote
Agree...that is a compelte bastard of a job.
Worse if you are putting in the restrictors as you have to push the airbox whilst trying to secure that attachment to the frame.
Not fun is it...
biker-dj
PostPosted: 16:39 - 08 Oct 2005    Post subject: Reply with quote
Thanks everyone for your help Thumbs Up and the detailed breakdown in the attached web-page. Its looking a bit fiddly to me so I may even have to pay out to have them removed Embarassed I am not the best at mechanical things i'm afraid but hey I might have a go!??!!
iCraig
PostPosted: 21:44 - 08 Oct 2005    Post subject: Reply with quote
Ah its easy!
If I can do it anyone can!
Until I got my GPZ500 last year I'd never taken any bike to bits before!
And this was my GPZ500 in April just before I sold it during its engine swap and I did most of that myself though I did get a hand from Keith.
https://www.gsxf.co.uk/engineless.JPG
instigator
PostPosted: 00:01 - 09 Oct 2005    Post subject: Reply with quote
Fiddly?
Nah mate, once you've done it, you'd seriously want to kick yourself if you had gave it to a garage to do. They'd charge upwards of £50 to do it and it only takes half an hour. Only difficult bit is getting the airbox back on but even then...if you just get someone to assist you for literally 2 minutes, doing that, then you'll encounter no problems.
You can always post on here if you get any problems Wink
biker-dj
PostPosted: 16:37 - 09 Oct 2005    Post subject: Reply with quote
Oooh, you are all making me feel guilty, perhaps I should crack it myself cos 50 quid is not something I want to lay out at the mo!! My biggest fear is I'll get so far and cock it up, but like you all say I've always got you lot to help out via posts etc. Cheers y'all Thumbs Up
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 107.14 Kb
