Kwak ZXR750J--Wiring Ignition To Run Without Key
nickm
PostPosted: 11:01 - 03 Oct 2005    Post subject: Kwak ZXR750J--Wiring Ignition To Run Without Key Reply with quote
i'm looking to run m7 zxr750j without the ignition switch and key--can anyone advise me which wires to join for ignition on then starter?
there are 6 wires on the connector which are orange/green, red, grey, blue, white, black/white, there is also a single brown on a bullet connector-any advice appreciated, also won't need any lights etc to work if that's relevant because they've been removed
Gazdaman
I did a trackday!!!
PostPosted: 13:28 - 06 Oct 2005    Post subject: Reply with quote
If you've got a wiring diagram I can tell you.
Should be one at the back of any haines manual. A lot of people wire the ignition into the switchgear somewhere. Although personally I'd keep the key configuration.
Gaz
nickm
PostPosted: 16:09 - 06 Oct 2005    Post subject: zxr750 wiring Reply with quote
hi gaz
thanks for that m8-i've decided to follow your advice and keep the key and lock--safer that way and one less thing to worry about
nick
PostPosted: 00:46 - 07 Oct 2005    Post subject: Reply with quote
One thing to watch out for if you do use switches is that they sometimes put a resistor in one of the circuits in the ignition switch. This means that should someone hotwire it then the resistor is missing and the ignition unit decides to suppress the spark.
nickm
PostPosted: 16:12 - 07 Oct 2005    Post subject: zxr750 Reply with quote
hi keith
thanks for replying-another good reason for me sticking to the ignition key option, 'spose i just wanted my bike to look more 'racerish'
cheers m8
Gazdaman
I did a trackday!!!
PostPosted: 21:28 - 07 Oct 2005    Post subject: Reply with quote
Doesn't get much more racerish than this... Note key.
Bendy
Mrs Sensible
PostPosted: 12:13 - 08 Oct 2005    Post subject: Re: zxr750 Reply with quote
Right, the quick guide.
Arrow Remove all lights and indicators.
Arrow Remove speedo.
Arrow Remove pillion pegs.
Arrow Swap existing fairings for ill-fitting fibreglass ones.
Arrow Paint it. Badly.
Arrow Take an angle grinder to your engine covers to mimic the effect of multiple lowside.
Arrow Remove one clipon. Bend. Replace.
Arrow Apply copious amounts of gaffa tape to anywhere that looks like it needs 'protecting'.
Arrow Take the can off and run over it with your car. Replace.
Arrow Paint it badly again. A proper race bike should have at least three schemes underneath the current one, so they show through when you chip the top one.
Arrow Take a hammer to the tank and apply a dent to mimic the 'my nuts hit it here' dent that all good race bikes have.
Arrow Dribble some fibreglass resin about strategically to make it look like you've patched it up after a huge smash.
Congratulations! You now have an authentic looking race replica. Very Happy
nickm
PostPosted: 12:24 - 08 Oct 2005    Post subject: racer Reply with quote
that sounds like the spondon framed cr500 i raced in the early 90s or should i say the bike i lost my bottle on in the early 90s-people who haven't been out there really don't know how hard it is to make the transition from fast road to track
Davo
Davo To The Rescue!
PostPosted: 12:25 - 08 Oct 2005    Post subject: Reply with quote
Failing that you could PM White Noise and ask him for some parts to make it look good!
The last post was made 20 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 62.49 Kb
