ZX9R B1 DOWNPIPES/END CAN OVERHEATING VERY QUICK
faith183uk
PostPosted: 04:15 - 08 Oct 2005    Post subject: ZX9R B1 DOWNPIPES/END CAN OVERHEATING VERY QUICK Reply with quote
Hello all,
I have a 1994 ZX9R B1 model. Being a kawasaki my downpipes were completely rusted through and falling apart.
I was still running the originals and the standard factory end can. As i needed to replace the downpipes i thought i would change the can at the same time.
After looking around Ebay,mcn etc the pipes were going to set me back £200 - £250 and a decent can about the same again.
In the end i opted for Motad Stainless steel Downpipes (MOTAD not MICRON which i know are poor for the money) and a custom made straight through race can for a nice deep sound.
Since having this done, my exhaust, both link pipe and can get bloody hot within 3-5mins of riding. The temp. must be in excess of 120 Oc.
The temp gauge on the bike is running as normal.
I was told that due to me changing the carbs and the are not in sync, this is causing the overheating of the pipes and can?
Any ideas?
Thanks in advance
sickpup
Old Timer
PostPosted: 09:18 - 08 Oct 2005    Post subject: Re: ZX9R B1 DOWNPIPES/END CAN OVERHEATING VERY QUICK Reply with quote
faith183uk wrote:
Hello all,
Any ideas?
Thanks in advance
First of all theres nothing wrong with Micron systems. In fact you would probably get better performance from one than from the Motad as they are not styled after the original.
Second. When did you change the carbs and what to?
Third. 120degrees isn't that hot, I would expect it to be higher.
4th. Did you use new exhaust gaskets.
5th. did you rejet or fit a factory pro/dynojet kit?
But to be honest the chances are the bike is running lean which produces heat do to carburation not being set up right.
Ichy
PostPosted: 17:10 - 08 Oct 2005    Post subject: Reply with quote
Just something I've noticed. Aftermarket exhausts are generally made out of thinner walled tube, this could cause it to heat up quicker although the general temperature should be similar.
PostPosted: 17:42 - 08 Oct 2005    Post subject: Re: ZX9R B1 DOWNPIPES/END CAN OVERHEATING VERY QUICK Reply with quote
Chances are it is running lean and hot, but this is not likely to show on the temperature gauge as it will have plenty of spare capacity to keep the engine block cool (the piston crowns are another question entirely).
faith183uk
PostPosted: 21:24 - 08 Oct 2005    Post subject: Reply with quote
Thanks for the responses its much appreciated.
Micron downpipes, i worded it a bit wrong, i meant for the money the local shop was asking i believed it would have been a poor choice. I didnt mean to suggest that micron pipes were poor in general - my mistake, apologies.
The carbs were changed for another pair purely for the fact the last ones where leaking and shot and i had a new set from the later B3 model. The only difference is the B3 carbs have a heating jacket where as the B1 doesnt, nor does it have the take off points from the radiator to fit one.
So in this case the carbs are still running the oringal jets.
Thanks though for the replies, i agree that the bike must be running lean to account for the temp. I had a quick spin on it the other night and tested the temp on the link pipe. 194oC. so i was a little out with the 120oC
So if its running lean whats the next step. Re jetting the carbs?
pipnet11
PostPosted: 21:32 - 08 Oct 2005    Post subject: Reply with quote
You need richer jets due to the exhaust system now being less restrictive than the original. If you run it like it is you run the risk of dead exhaust valves or melted piston crowns.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
PostPosted: 22:08 - 08 Oct 2005    Post subject: Reply with quote
Yes you will need to rejet, and likely need someone with a dyno who knows what they are doing.
The Dynojet kits are a good starting point, but they are not just a lob on and forget item. You need to make the right choice of needle jet position, main jet, etc.
faith183uk
PostPosted: 23:48 - 08 Oct 2005    Post subject: Reply with quote
Good stuff, i will book it in with PDQ this week. In the mean time i will not ride it.
Thanks Kieth and the rest of you for all your help. Its appreciated.
faith183uk
PostPosted: 23:51 - 08 Oct 2005    Post subject: Reply with quote
Oh just one more question.
I take it the 2 foot flames out the end can at high revs again is due to it running lean?
PostPosted: 11:36 - 09 Oct 2005    Post subject: Reply with quote
Mmmm, maybe, but sounds more like rich.
Also check for air leaks in the exhaust. Make sure you use new exhaust gaskets and check the joints are sealed.
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 67.04 Kb
