removing brake fluid
White Noise
Mr Dudwee
PostPosted: 17:58 - 09 Oct 2005    Post subject: removing brake fluid Reply with quote
anyone got any tips for removing brake fluid without replacing it with fresh fluid and not getting it everywhere!
WN
sickpup
Old Timer
PostPosted: 18:06 - 09 Oct 2005    Post subject: Reply with quote
No. Replace it.
PostPosted: 18:15 - 09 Oct 2005    Post subject: Reply with quote
If you mean to get it out of the system so that you can work on it, try a syringe or a turkey baister.
White Noise
Mr Dudwee
PostPosted: 19:48 - 09 Oct 2005    Post subject: Reply with quote
need it out as going to replace the lines while i get the caliper sorted out
well me and davo had an interesting approach to it by feeding the front resivour and lever down the forks and front wheel then releasing the banjo bolts clear of paint, was a backward way to do it but seemed to work ok
WN
Guest
PostPosted: 20:24 - 09 Oct 2005    Post subject: Reply with quote
Just unbolt the banjo bolts at the caliper, stick the pipes into a jam jar and then pump the fluid out via the lever. That'll shift the bulk of it, still be careful of spill when you undo the rest though.
fuzz
PostPosted: 21:47 - 09 Oct 2005    Post subject: Reply with quote
Get yourself a Mityvac. Not cheap, but saves so much hassle for these kind of jobs. You can use it like a syringe to drain your reservoir aswell as pull fluid through the system quickly.
White Noise
Mr Dudwee
PostPosted: 21:52 - 09 Oct 2005    Post subject: Reply with quote
Google wrote:
Mityvac - Making vacuum extractor cups and gel products for obstetric and gynaecological use.
i'll leave that for now! Laughing though think its about £35, maybe next time.
WN
fuzz
PostPosted: 22:11 - 09 Oct 2005    Post subject: Reply with quote
LMAO Laughing
Jamie_ducati
PostPosted: 11:28 - 11 Oct 2005    Post subject: Reply with quote
Works for me!
Jamie
Time for eDUCATIon
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 60.35 Kb
