Need some advice
westendboy7
PostPosted: 11:52 - 10 Oct 2005    Post subject: Need some advice Reply with quote
Hi all
Got a bit of a problem. Am respraying my Suzuki GSX600F. Got all the panels off except one. The front mudgaurd is held with 8 allen screws but the buggers won't budge. Any ideas would be greatly appreciated
Cheers Mike Crying or Very sad
Clanger
Stirrer
PostPosted: 11:55 - 10 Oct 2005    Post subject: Reply with quote
WD40 - jesus spray, tends to make everything budge
PostPosted: 12:09 - 10 Oct 2005    Post subject: Reply with quote
Or longer allen keys?
You might even be able to get an allen bit into an impact driver which should crack them out, just be careful as the bits aren't designed for impact use and could shatter (although I have never had it happen). I suppose this depends on if you have room to swing a hammer.
westendboy7
PostPosted: 12:25 - 10 Oct 2005    Post subject: Reply with quote
tried both of those. left wd40 on all night but no joy. allen bit no good cos the bottom yolk in the way. thanks fellas
18_stuart_88
PostPosted: 12:45 - 10 Oct 2005    Post subject: Reply with quote
Howz about a rench with a allen key bit? Dont know if you would have the bit but worth a try if you do!
Stu
Clanger
Stirrer
PostPosted: 18:42 - 10 Oct 2005    Post subject: Reply with quote
thats okay, but I aint a fella!!!
westendboy7
PostPosted: 22:52 - 10 Oct 2005    Post subject: Reply with quote
Ahh! A touch of gender confusion. Wink Ok then. Thanks you guys
bish777
PostPosted: 22:57 - 10 Oct 2005    Post subject: Reply with quote
give them several sharp whacks from a hammer, then stick a length of tube over the end of the allen key so you can get mondo leverage.
GSXR1100J
westendboy7
PostPosted: 23:01 - 10 Oct 2005    Post subject: Reply with quote
Cheers bish. Although I did think of that until i got on the floor and noticed the bottom yolk is quite close. Tried the tube idea too. Flipping allen key slipped round. Think I'll just have to spray it while it's still on the bike.
Mike Evil or Very Mad
Mantzy
PostPosted: 01:35 - 11 Oct 2005    Post subject: Reply with quote
Have you got a torque wrench/long ratchet with a 1/4" shank? If so, go to B&Q and get a Torq set of bits and ratchet screwdriver. Costs about £2.95. In that there is a 1/4" socket. Also in the set is a 4 and 5mm hex bits which fit into the 1/4" socket perfectly.
Attach the two together and you can tighten/loosen hex bolts easily. I've found it bloody impossible to find 1/4" sockets with 1/4" shank except in that set. Even the tool shops and specialists don't have them, unless you buy 10 for £30 or so!
Might want to try a length extension on the ratchet too to get around the depth of the guard
HTH
R
Current Bikes: 2010 Triumph Sprint ST 1050
Previous Bikes: 2002 Sachs XTC, 1999 Kawasaki ZX6R, 2004 GSX-R 600 K4, 2006 Yamaha XT660X
Walloper
PostPosted: 07:18 - 11 Oct 2005    Post subject: Reply with quote
HHS Drill bit.
Drilling machine
Question
westendboy7
PostPosted: 12:21 - 11 Oct 2005    Post subject: Reply with quote
Some great ideas here but in the I got the hump and threw a wobbler. I masked up the front of the bike and sprayed the bloody thing where it was. Nice job job tho. Even if I do say so myself. Thanks all
The last post was made 21 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 71.98 Kb
