Help needed changing a DVD into an Mpeg
Bike Chat Forums Index -> General Bike Videos Goto page 1, 2  Next
Gilderoy
PostPosted: 20:36 - 10 Oct 2005    Post subject: Help needed changing a DVD into an Mpeg Reply with quote
Got an onboard video of croft circuit (for the track guides section) but the video recorder will only write it to a DVD? How can I change it to an Mpeg for posting? I guessed Windows Movie Maker but was unsure?
veeeffarr
PostPosted: 20:44 - 10 Oct 2005    Post subject: Reply with quote
Have you tried it with Windows Movie Maker?
Gilderoy
PostPosted: 20:47 - 10 Oct 2005    Post subject: Reply with quote
Just getting it off Kazaa now so we'll see......
White Noise
Mr Dudwee
PostPosted: 20:52 - 10 Oct 2005    Post subject: Reply with quote
try this https://flaskmpeg.sourceforge.net/
its freeware and easy to use, that what i used for my vid at silverstone
WN
haGGard
PostPosted: 22:47 - 10 Oct 2005    Post subject: Reply with quote
I use a program called 'Yasa - Vob 2 mpeg'
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
Gilderoy
PostPosted: 23:22 - 10 Oct 2005    Post subject: Reply with quote
[quote="White Noise"]try this https://flaskmpeg.sourceforge.net/
tried this mate and it doesn't recognise the files, windows movie maker says the same??
The disc holds two folders, Video_RM and Video_TS? each folder contains files that my system can't understand?
White Noise
Mr Dudwee
PostPosted: 23:30 - 10 Oct 2005    Post subject: Reply with quote
it should read files with the .VOB extension
WN
Gilderoy
PostPosted: 00:12 - 11 Oct 2005    Post subject: Reply with quote
Cheers WN, that seems to be doing the trick.
Does it usually take a long time? Mine's going very slow?
Rich
White Noise
Mr Dudwee
PostPosted: 00:34 - 11 Oct 2005    Post subject: Reply with quote
depends how big the file is, one trick i use is to copy the files to your hard disk first then read them from there as the acess speed will be quicker than it is trying to get it off the DVD
WN
Gilderoy
PostPosted: 20:36 - 11 Oct 2005    Post subject: Reply with quote
OK so it's in Mpeg format just need to come up with something on Movie maker?
Rich
White Noise
Mr Dudwee
PostPosted: 20:46 - 11 Oct 2005    Post subject: Reply with quote
Rich
yeah you can load it up into movie maker then save it as a WMV and you can specify the size of the file you want to produce
WN
Gilderoy
PostPosted: 22:54 - 11 Oct 2005    Post subject: Reply with quote
Right, for some reason once i've cut it the quality of the video and sound are really crap???
White Noise
Mr Dudwee
PostPosted: 22:58 - 11 Oct 2005    Post subject: Reply with quote
how big is the file you are wanting to create and how long in time is the clip you are trying to convert?
WN
Gilderoy
PostPosted: 23:01 - 11 Oct 2005    Post subject: Reply with quote
WN
it's 24 mins on the dvd but i've cut it down to 12 mins
White Noise
Mr Dudwee
PostPosted: 23:03 - 11 Oct 2005    Post subject: Reply with quote
the vid i posted was about 1 min 10 secs and that was 10 MB, so try setting the output file to be 110 MB. what have you been setting it at before?
WN
Gilderoy
PostPosted: 23:32 - 11 Oct 2005    Post subject: Reply with quote
WN
Mate I haven't a clue what I'm doing with movie maker? I just left it to the original setting?
Gilderoy
PostPosted: 23:39 - 11 Oct 2005    Post subject: Reply with quote
the size is 497MB at 24 mins but after i cut it it was about 12 mins so less than half that but still a really bad picture?
White Noise
Mr Dudwee
PostPosted: 23:40 - 11 Oct 2005    Post subject: Reply with quote
ok, this is what i did, open the clips that you want and drag them into the timeline, then under "3. finish movie" click on "save to my computer" then name the file and where its to be saved. click next and it will give you the options, choose "best fit to file size" and stick 110 MB in there. click next and it will make the movie for you. try that out and see what results you get Thumbs Up
WN
Gilderoy
PostPosted: 00:21 - 12 Oct 2005    Post subject: Reply with quote
Cheers WN that seems to have done it, I'll up load it if I can.
Anyone feel free to modify it and add music etc as the sound keeps going off, it seems the the mic can't cope with 107db oumping out of the pipes.
Gilderoy
PostPosted: 11:40 - 12 Oct 2005    Post subject: Reply with quote
ok when i add it as an attachment, after about 20 mins it comes up with something like no post mode specified?
cbrbiker
PostPosted: 16:58 - 12 Oct 2005    Post subject: Reply with quote
I doubt you can attach to a post mate. Try uploading it to www.putfile.com instead and posting a link.
My Bikepics page
www.trackdaypix.com
Gilderoy
PostPosted: 17:07 - 12 Oct 2005    Post subject: Reply with quote
It seems that the highest i can load up is 25mb and the video clip is 107??
cbrbiker
PostPosted: 17:44 - 12 Oct 2005    Post subject: Reply with quote
Arse. Use something like "ImTOO MPEG Encoder" (www.download.com I think is where I got it from) to resize the clip into a more manageable size.
My Bikepics page
www.trackdaypix.com
Gilderoy
PostPosted: 17:59 - 12 Oct 2005    Post subject: Reply with quote
ok got it down to 25mb and uploading it to putfile.com, how long does it usually take??? I've 2mb broadband.
cbrbiker
PostPosted: 18:12 - 12 Oct 2005    Post subject: Reply with quote
Ah, but your 2MB will only be downstream, not upstream. So you're probably looking at more like 1MB upstream (which is still faster than my downstream!). You'll probably get an upload speed of around 70kbps I would guess, so 70k per second, probably means about 1MB a minute or so.... go and make a cuppa and check back in half an hour! Razz Wink Laughing
My Bikepics page
www.trackdaypix.com
The last post was made 20 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 127.57 Kb
