deristrict the nsr 125 rk
nsr_rk_boy
PostPosted: 12:39 - 11 Oct 2005    Post subject: deristrict the nsr 125 rk Reply with quote
can any of u biker dogs help me deristrict my nsr125 rk it only does 70 on a straight the exhaust has had the bit drilled out inside and the carb has been done but its slow as my girlfriend.
alains
PostPosted: 13:38 - 11 Oct 2005    Post subject: Reply with quote
when you said the carb has been done , what do you mean by that ?
on de-restriction you need to be accurate
knockout_bar
PostPosted: 14:07 - 11 Oct 2005    Post subject: Reply with quote
It's not just a case of drilling a hole through the restricter, you need to completely clear out the bit in the pipe, where it was. Should be completely straight through.
125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) Thumbs Up
nsr_rk_boy
PostPosted: 14:23 - 12 Oct 2005    Post subject: Reply with quote
the restrictor in the exhaust has been drilled and taken right out and as the carb goes there was a ristrictor restricting air flow wat do u all recon can u help me
alains
PostPosted: 14:54 - 12 Oct 2005    Post subject: Reply with quote
now, you need to look which kind of electronics are on
number written on the CDI , number written on the RC valves control unit . this writings are generally in white . report & i will tell you
also it will a + if you know which jets are in your carb
nsr_rk_boy
PostPosted: 17:03 - 12 Oct 2005    Post subject: Reply with quote
ok where about is the cdi unit on the rk
alains
PostPosted: 17:17 - 12 Oct 2005    Post subject: Reply with quote
somewhere in front of the battery . download the workshop manual and you will find it . adress of the manual is contained in this file :
https://www.geneva-racing.com/~alains/NSRtips.doc
download it , you will find anything you need
The last post was made 20 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 49.84 Kb
