| Slinn84 |
 Slinn84 Scooby Slapper
| instigator |
 instigator Super Spammer
 Posted: 22:24 - 12 Oct 2005 Post subject: |
£40 perhaps a little more. Depends on how easy it is to remove the forks on that particular bike (do any plastics need taken off) Time is money.
Get yourself a thin metal tube a little bigger in diameter than the fork (the shiny bit that moves, god I can't remember the name) and do it yourself that way. Bit of brute force and it's an easy job.  |
| White Noise |
 White Noise Mr Dudwee
 Posted: 22:29 - 12 Oct 2005 Post subject: |
doing it on my ZX at the mo, taken out the forks myself and taken them to the garage, he recons £50 parts and labour. (2 X oil and dust seals)
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| instigator |
| Slinn84 |
| White Noise |
| White Noise |
| instigator |
 Posted: 22:57 - 12 Oct 2005 Post subject: |
| Slinn84 |
 Posted: 23:19 - 12 Oct 2005 Post subject: |
i used to use a pretty similar method to get the front wheel up when changing the discs, two car jacks, one on either side of the crankcase
gets it up no probs, but the front paddock stand is much easier
no good for removing the forks tho.
i wanna give it a go but i've read the haynes manual and it seems very tricky to me
having to compress the forks to un-do screws and thread different things in certain places, and alsorts of stuff
on a scale of 1 to 10, how hard would you say it is to get to the seals??
1 being stupidly simple, (eg turning ignition on )
and 10 being the hardest, (eg engine, and gearbox overhaul)
cheers guys |
| White Noise |
| G |
 G The Voice of Reason
 Posted: 23:51 - 12 Oct 2005 Post subject: |
USD forks like those fitted to WNs ZX7R tend to be far more difficult to disassemble.
Normal forks are usually quite easy. However from what you say I would guess the Thundercat must have some adjusters on the top of the fork.
Normally crack off the bolt at the bottom, take off the top of the fork, remove the spacer, remove the spring, tip the oil out, fully undo the bolt at the bottom, take off the dust seal, remove the circlip above the fork seal and then just yank the top and bottom apart.
| Slinn84 |
 Posted: 00:58 - 13 Oct 2005 Post subject: |
well i'm gonna go for it
got the damper and pre-load adjusters on the top so the damper needs removing
all very fiddly but i've got all weekend off so i'm gonna order all the parts, dust seals, oil seals etc, then give it a go
cheers for the help guys  |
| Robby |
 Robby Dirty Old Man
The last post was made 21 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
