getting rid of flat spots.....................:)
riichy
PostPosted: 13:10 - 13 Oct 2005    Post subject: getting rid of flat spots.....................:) Reply with quote
i got a race can off "ric Thumbs Up fella " and that made the flat spot not as bad but is there anyway to get ride of it all.......i herd you can get carbs tweked,
any suggestions zxr400er.......... Mr. Green
.......... PLOD ............ zx636 2004
Walloper
PostPosted: 13:12 - 13 Oct 2005    Post subject: Reply with quote
Take it to a good bike garage.
You may need the carbs balanced or the mixture adjusted to suit the change in gas flow through the engine.
My T'cat needed it done when I fitted a Micron can but I never noticed any big probs.
riichy
PostPosted: 13:15 - 13 Oct 2005    Post subject: Reply with quote
the ART race can is only an end can though not a full system......but i might take it to a garage sometime....
ps waloper you pic its cahnged Sad
bish777
PostPosted: 19:23 - 13 Oct 2005    Post subject: Reply with quote
Your running the stock airbox and filter i presume?
Take the carb tops off and remove the slides.
Take the needle out of the slide.
You will see the needle has a clip on it.
Move the clip down to the next notch below-this will raise the needle and make the fuel mix richer.
Try it out and see if it improvesd much, if not put the clip in the next lower notch.
You may also have to go to a larger main jet, but try the needle first.
GSXR1100J
Jrod
Page 3 Girl
PostPosted: 01:00 - 14 Oct 2005    Post subject: Reply with quote
Is it between 3.5 and 4k?
Get your carbs balanced. Thumbs Up
Walloper
PostPosted: 02:00 - 14 Oct 2005    Post subject: Reply with quote
I never knew it needed 'Board Approval'. It was taking to much shit anyway.
People saw it and just opened up on me. Laughing
benc
PostPosted: 03:50 - 14 Oct 2005    Post subject: Reply with quote
i wud suggest get the carbs balanced first to see if that helps. if not get it set up on dyno which might help, then getting a dyno jet kit. but make sure if you want to get a new air filter or what ever fit that first to save money and get it all done at once.
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 51.92 Kb
