| illusion |
 illusion Scooby Slapper
| mr.z |
 mr.z World Chat Champion
 Posted: 18:12 - 15 Oct 2005 Post subject: |
Have some, work very well, a little too well you could say... they will stop water going in OR out, so you can wade in a huge puddle but your feet sweat will stay in there.
If you wear thin socks underneeth and them over the top theres less of a problem with it..
Very usefull when it gets to minus numbers, just be picky when you use them. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| gimpy limp |
 gimpy limp Nearly there...
 Posted: 18:29 - 15 Oct 2005 Post subject: |
surely with it being gortex it would stop water getting in but let condensation/air out? My army camping bivvy bag i'd use over the sleeping bag was gortex and lets water+air out (you could tie it up almost completely so your nearly fully covered and still breath in it). ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| mr.z |
 Posted: 18:34 - 15 Oct 2005 Post subject: |
They should but they don't
There not bad, i've rarely felt the need to use them as most of the rideing i do is no more than an hours ride at a time (in the dead of winter anyway)
Used them with sidi vertibre boots in -5 and my feet were still warm enough (was more concerned with the rest of me tbh) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| illusion |
| Liono |
 Liono Spanner Monkey
 Posted: 11:03 - 16 Oct 2005 Post subject: |
Gore Tex is a breathable material, but it relies on being able to move the moisture away from the outer surface. If you wear them inside a pair of leather boots which become saturated from the wet the membrane will quickly lose its effectiveness and you might as well put your feet in plastic bags. I've never used the British Army issue socks like that, but I think they are designed to keep water out rather than heat in, although they will have the side effect of being slightly warmer. If you are getting wet feet, buy some fully waterproof boots, or try some Sealskinz. If you just want warm feet, go to an outdoor/ski type shop and get some decent liner socks (silk for preference) and some decent ski socks. Make sure you don't have any tight spots in your boots too, as these will restrict blood flow and give you cold tootsies. |
| illusion |
| gimpy limp |
 Posted: 13:24 - 16 Oct 2005 Post subject: |
when we used to go camping and hiking alot theirs these extra fluffy sort of socks made of some material that you can wear over normal socks or much better over thinner socks to keep you toastie. They were great under some waterproof boots and overboots. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
The last post was made 20 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
