| colin1 |
 colin1 Captain Safety
| stinkwheel |
| Akiraprise |
 Akiraprise Nitrous Nuisance
| colin1 |
| OreoXX |
 OreoXX Nova Slayer
 Posted: 14:53 - 17 Oct 2005 Post subject: |
My NSR also has some odd vibration, and it just started recently. I have no clue what it is, but it might be the same problem you are facing. Report back when you figure out what the problem is, and I'll do likewise if I find the problem with mine  |
| veeeffarr |
 veeeffarr Super Spammer
| colin1 |
| colin1 |
| Kickstart |
 Kickstart The Oracle
| Finglonga |
 Finglonga World Chat Champion
| Kickstart |
| priller |
 priller Brolly Dolly
| Kickstart |
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 18:32 - 20 Oct 2005 Post subject: |
Yep all the AR6 engines have balancer shafts, same engine that is used in my rx if you need the manual, ive got a .pdf file for the engine, gimme a pm if you need it, good luck  ____________________ Will work for petrol
My Design Blog |
| Kris |
 Kris World Chat Champion
 Posted: 17:40 - 21 Oct 2005 Post subject: |
My NSr started vibrating really bad after a spill. Found out at the garage that the engine was being held in by one bolt after the others sheared off.
I'd try that first. ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| kenny |
 kenny Nearly there...
 Posted: 22:52 - 21 Oct 2005 Post subject: |
it is a strong possiableity that it is the mounting bolts as 2 strokes vibrate alot more then 4 strokes which means stuff often come lose just take out the bolt completely and add some nut lock (locktight) to the end of the bolt and replace and torque up to the right torque if you can
use the blue nut lock i think the green stuff might be a bit to strong for them
hope that helps  ____________________ KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6 |
| colin1 |
| lilredmachine |
 lilredmachine World Chat Champion
| Aikman666 |
 Posted: 12:51 - 22 Oct 2005 Post subject: |
The balancer shaft is only there to reduce vibration, if its a problem with that, other than it vibrating like a normal 2stroke would, i dont think it would do much damage. ____________________ Will work for petrol
My Design Blog |
| Kickstart |
 Posted: 13:30 - 22 Oct 2005 Post subject: |
If it is an engine mounting bolt then possible you will wear the mounting holes to an oval shape.
Short term you will probably get away with the vibration. Longer term it is going to put extra stress on many engine components (eg, crankcases). Also remember that depending on how the gears have failed you could have a load of bits of plastic floating around in the crankcases.
Just checked the Rotax workshop manual and it says to replace the balance shaft drive gears every 15000km.
| colin1 |
The last post was made 20 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
