indicator problem
Mrs Knight
PostPosted: 14:36 - 16 Oct 2005    Post subject: indicator problem Reply with quote
I was wondering if anyone could post-up some info for me. Confused
The left indicator on my suzuki GP125 does not flash on-off. When it is switched on, the light remains on constantly. Right side is working fine.
Any ideas what I can do to fix it?
Thanks
Aimee
Akiraprise
PostPosted: 14:59 - 16 Oct 2005    Post subject: Reply with quote
I've got this problem on my RS - I'm going to try a different relay - a more powerful one.
have you changed your indicators recently? dropped the bike or anything - when did they start doing this? Also might want to check all connections make sure they're fine
good lcuk finding the problem
Slinn84
PostPosted: 15:31 - 16 Oct 2005    Post subject: Reply with quote
do both end stay on?? front and rear i mean?
if your bulb has gone then one working one will flash more rapidly so that cant be the problem
do you have an indicator light on the display? that flashes when your indicators are on. does this stay on and not flash?
chack all the connections on the indicator circuit, might be a faulty connection close to your relay. a more powerful relay will not help as this will cause the flash rate to increase.
Mrs Knight
PostPosted: 16:49 - 16 Oct 2005    Post subject: display light stays on instead of flashing. Reply with quote
Thanks for the suggestions!
I've not had the bike long and it was on the 2nd ride out (yest) that the problem started.
The bike has not been dropped or had the indicators replaced since I've owned it (all of a few weeks).
The display does show a constant light for the left, but flashes on/off as would be expected for he right indicator.
I will get my other (more practical!) half to check out the electrics / connections.
dodsi
Dirty Carny
PostPosted: 17:09 - 16 Oct 2005    Post subject: Reply with quote
When I rode the bike through york I found that when you stopped at lights the indicators would just stay on and not flash. as soon as you rev the engine a bit they begin to flash again.
Was much fun riding that little GP through york...even though It looked like a mini moto under me.
extreme3d
PostPosted: 18:22 - 16 Oct 2005    Post subject: Reply with quote
It could be a sticky relay. If the lights staying on it may mean the circuit is not being broken as it should.
muddycoffee
PostPosted: 00:33 - 17 Oct 2005    Post subject: Reply with quote
Is it a 6v system?
or anyway, even 12v make sure the battery is fully charged. The flashing relay is a bimetallic strip and uses lots of current to work. If there isn't enough current available then it won't have enough to break the circuit and the indicator will stay on.
When you rev the engine, a temporary amount of extra current is flowing from the alternator - enough to make the flasher work and the lights wink.
My advice is take the battery off and leave a full night's charging. If the battery is more than 5 years old you will almost certainly need a new one.
Good luck Thumbs Up
Suzuki SV650 naked Blue curvy with Givi Screen and G force can.
Black Knight
PostPosted: 08:25 - 17 Oct 2005    Post subject: Reply with quote
muddycoffee wrote:
Is it a 6v system?
Good luck Thumbs Up
We checked both indicators whilst idling at lights. For the same revs, RH worked but LH was on constant. Im not sure its the revs/current thats affecting it, plus im pretty sure the lady we bought it from had just replaced the battery.
Would it have two relays? One left and one right?
Cheers all. Thumbs Up
muddycoffee
PostPosted: 10:37 - 17 Oct 2005    Post subject: Reply with quote
no there will only be one flasher unit, (or relay as you call it, though it isn't really a relay) I suspect that you might have a weak bulb on one side but I would still charge up the battery fully. Purchase a spare indicator bulb and you can try it in the LH side first front then back.
Sometimes the solder on the back of a bulb gets a little (dry) and therefore the impedence of the joint goes up, in this case it might mean that the bulb comes on but pulls less current and this will mean that there is not enough current drawn to heat up the flasher and make it go off.
Black Knight
PostPosted: 10:52 - 17 Oct 2005    Post subject: Reply with quote
So you think maybe I should just give it a good clean?...or rather Mrs Knight should Laughing
The last post was made 20 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 64.21 Kb
