| veeeffarr |
 veeeffarr Super Spammer
| veeeffarr |
| mr.z |
 mr.z World Chat Champion
 Posted: 19:09 - 17 Oct 2005 Post subject: |
Pick the bike up and shake it arround, if anythings rattleing then it must be somthing daft has come loose.. (if your too weeny get a friend to help )
Is it at all times? certain revs? when its moveing? when its stopped? (if its moveing then check the drivetrain, chain, sprockets e.t.c. even suspension)
It could be almost anything really, short of going arround every bolt theres not much you can do!
If you get a long handled screwdriver and rest it on the engine you can use it to listen to different engine parts.
+ Check your oil level!
Even if you dont think its the keys take all of them off appart from the ignition key then try it. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| veeeffarr |
 Posted: 19:34 - 17 Oct 2005 Post subject: |
| mr.z wrote: | Pick the bike up and shake it arround, if anythings rattleing then it must be somthing daft has come loose.. (if your too weeny get a friend to help  )
Even if you dont think its the keys take all of them off appart from the ignition key then try it. |
Keys was the first thing I did Even though they were rattling quite violently, this wasn't the problem
I first notice it when I'm first pulling off in first gear, when I get to the top of the gear it makes the rattling sound, it seems like vibration from the engine is making something rattle  |
| mr.z |
 Posted: 19:39 - 17 Oct 2005 Post subject: |
Stick it in neutral, rev it all the way to the top after warming it up, if its not happening then its not the engine..
If so, put it on the centerstand* and then run it up and down second and first gear, checking arround for noises..
I'd guess its your chain, if its loose it may rattle against the case.. when changeing gear its not under as much tension (as far as i understand it)
(*It might be worth secureing it too, something like a ratchet tie from the stand to the front forks, that way it can't come off the stand and go flying into a wall, which does happen all too often) ____________________ >RidingSkills<->Tech Tips<->MyBikes<
| veeeffarr |
| mr.z |
 Posted: 19:44 - 17 Oct 2005 Post subject: |
don't suppose you have a pic?? where is it connected to? left side/right side (as your rideing) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| veeeffarr |
| Slinn84 |
 Slinn84 Scooby Slapper
| veeeffarr |
 Posted: 23:38 - 17 Oct 2005 Post subject: |
I haven't taking anything apart!
So far I have:
Tightened up all bolts around engine
Tightened the 4 bolts that hold the handlebars on
Tightened other bolts around the frame of the bike and checked for loose ones
There is up/down freeplay in my brake/clutch levers, is this normal? |
| mr.z |
 Posted: 00:05 - 18 Oct 2005 Post subject: |
Yes its normal, they do tend to flap arorund, dont worry about it (put your hand on them when the noise starts, if it stops thats your problem) dont tighten them!
+!!!Be very carefull tightening things without the torque values!!!
Like i said, it is very important when it happens, happening when its stopped or moveing, what rev ranges (or unrelated to the revs)
The screw thing... sounds bizzare, my cg is an older one so can't help you there because theres nothing like that.. the only thing i can imagine it might be is a crude breather valve, any excess pressure pushes it up to let the air out..????? you could try puting some blutack on it holding it open, shouldn't move arround so much then... if the sound stops then its not that.
Wondering one thing.. what revs are you changeing gear? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:10 - 18 Oct 2005 Post subject: |
| veeeffarr |
 Posted: 01:53 - 18 Oct 2005 Post subject: |
| veeeffarr |
The last post was made 20 years, 78 days ago. Instead of replying here, would creating a new thread be more useful? |
