 The Tot World Chat Champion
 fuzz World Chat Champion
 Posted: 13:45 - 18 Oct 2005 Post subject: |
If the chain was so loose that it came off the sprocket, you should be able to loosen the axle nut and push the wheel towards the front. You might then have enough to slip it over the sprocket and retighten. ____________________ https://www.bikepics.com/members/fuzzbcf/
 Redd World Chat Champion
 Posted: 16:49 - 18 Oct 2005 Post subject: |
Happened to me a couple of weeks ago. Entirely my own fault for riding when the chain was that slack but it had been raining for a week and I couldn't be arsed getting soaked to adjust it
Chain was jammed between the rear sprocket and the swingarm. A couple of big screwdrivers coaxed it free then carefully moving the bike forward to get the chain to catch on the sprocket sorted me out (followed by a prompt chain adjustment before riding home).
Big thanks to BanditsHigh for coming along and showing me what to do. It was obvious once he showed me, but I couldn't get the chain free and might have ended up doing something more drastic if he hadn't done the job with the screwdrivers) . ____________________ Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike |
 map Mr Calendar
 Posted: 17:01 - 18 Oct 2005 Post subject: |
Think you got lucky. A flailing chain can seriously hole an engine.
FWIW depends on the bike and what chain you're getting. If correct continuous loop you'll probably have to take the swingarm off to fit the chain. Sounds like you've got a workshop handy so shouldn't be any hassle whatever way you need to do it. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
