Bike Splutters in Heavy Rain!!
Twisted2004
PostPosted: 14:20 - 13 Oct 2005    Post subject: Bike Splutters in Heavy Rain!! Reply with quote
When it really really pours down, my bike splutters when accelerating!!
I'm thinking water must be getting into the fueling system somewhere! or the plugs maybe??
ideas?
Cheers.
(XJ600S Diversion)
Previous : DT125 > XJ600S > YZF1000R > Honda CBR1000RR-8 Fireblade (White) - Stolen > Honda CBR125R> Honda CBR1000RR-8 Fireblade (Red)
Current : Ducati Multistrada Pikes Peak (For Sale)
romperstomper...
PostPosted: 18:13 - 13 Oct 2005    Post subject: Reply with quote
has it got a sports air filter ,water can get in if its not oiled !
Twisted2004
PostPosted: 22:04 - 13 Oct 2005    Post subject: Reply with quote
nope its just got a standard air filter system
romperstomper...
PostPosted: 22:44 - 13 Oct 2005    Post subject: Reply with quote
well thats about the full extent of my knowledge I'm afraid Embarassed
come on guy's help him out !
just a last thought try spaying wd40 all around the engine ,spark plug/leads etc.
instigator
PostPosted: 22:54 - 13 Oct 2005    Post subject: Reply with quote
Common fault with the sv is that water gets into the spark plug cap/surrounding area and it causes it to "cough & splutter" and sometimes run on one cylinder. The divvy is obviously a IL4 (yes) but it may suffer from the same problem. Try take the plug caps out, dry them and wd40 them. As one they are wet, they can actually stay wet for a prolonged period.
I'm guessing the bike doesn't have a fender extender? If not, I would recommend one as it may solve your problem. Smile
sickpup
Old Timer
PostPosted: 23:24 - 13 Oct 2005    Post subject: Reply with quote
Good call that chap.
Common on a lot of old Suzuki's such as oil cooled GSXR's and Bandits which have vented plug caps and no plug hole drains. Used to use silicone to seal up the outer two cylinders.
Twisted2004
PostPosted: 01:04 - 14 Oct 2005    Post subject: Reply with quote
whats a fender extender?
instigator
PostPosted: 09:47 - 14 Oct 2005    Post subject: Reply with quote
https://www.performancemotorcycleparts.co.uk/bodywork_pages/powerbronze_fender_extenders.htm
As you can imagine, the front wheel spits up dirt/water from the ground onto your engine. The fender extender basically extends the cover of your mudguard and reduces the amount of crap flung onto the bike. (well, reduces, it reduces the height that it will reach as well)
If you look around on ebay, I believe you can get them for £19. Thumbs Up
https://www.adventuremotogear.com/images/hi-res/f-sv650.jpg
That black bit of plastic, attached to the mudguard. Smile
Twisted2004
PostPosted: 11:19 - 14 Oct 2005    Post subject: Reply with quote
Thanks people, i really apprieciate your help!
mr.z
PostPosted: 12:15 - 14 Oct 2005    Post subject: Reply with quote
When you get the tank off next check the spark plug lead all the way up to the coils (should be two) even then there might be no obvious problems so its hard to say..
Try takeing the plugs out and cleaning the recess where they cap goes in, sealing it might be an idea like sickpup mentioned.. if that dont help new plugs and caps are the next step, see if you can cover the coils in any way? (heared of people covering cg125 coild with an asda bag)
Good luck getting it fixed, i had similar rian induced intermitant problems on a previousd bike and it was a right git to get fixed, think i finaly fixed it but it totaly destroyed my confidence in the bike as it was completely without warning and totaly random Thumbs Down
Akiraprise
PostPosted: 15:14 - 16 Oct 2005    Post subject: Reply with quote
if the above doesn't work - which it should, also check all electrical connections, if one's not properly covered and gets some water on it it will cause the same symptons,
Twisted2004
PostPosted: 17:36 - 16 Oct 2005    Post subject: Reply with quote
when i get a chance to have a look i'll let you know what i uncover!
Thanks again for the help
Joey Bane
PostPosted: 11:11 - 20 Oct 2005    Post subject: Reply with quote
wd-40 use to fix probs caused by moisture in the electrical system
Currently driving: Motorhispania RYZ(yes i'm another ped "boi")
The last post was made 20 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 78.1 Kb
