K&N and Dynojet
chunkielad
PostPosted: 00:24 - 07 Mar 2003    Post subject: K&N and Dynojet Reply with quote
Ok lets assume I decide not to change the GS for something sporty but instead, decide to get more power from the GS itself.
It has a MOTAD Nexxus exhaust and I wondered about K&N and Dynojet kits for the extra Umph.
Here lies the problem - I can defo do the airfilters and pretty sure I can do the jets in time but I don't know what the fook I'm buying!
Do I get a Stage1,2 or 3? What is the difference? Will I need a specific jet size - how do I know which one? Can I do the filters and not the jets?
Ropehead
PostPosted: 00:31 - 07 Mar 2003    Post subject: Reply with quote
the K&N will increse the airflow making the fuel 2 air mixture weak and overheating your engine so ......Yes u do need to get it re-jetted to run propperly and its quite an artform ,
Probabley worth fitting all your performace parts in one go and getting it Profetonaly set up then u get the pice of mind Smile
chunkielad
PostPosted: 00:33 - 07 Mar 2003    Post subject: Reply with quote
Not worth trying myself then?
WildGoose
White Van Man
PostPosted: 00:40 - 07 Mar 2003    Post subject: Reply with quote
not going blind, if you had intruction, or a setting up guide particular to the GS then it would be easy enough i guess, but i wouldnt guess at it
Ropehead
PostPosted: 00:41 - 07 Mar 2003    Post subject: Reply with quote
if u can find someone with the same setup u could work from that and u wont be far off Very Happy
just have a GOOD read up on jetting and plug chops,
have u tryed
https://www.gstwin.com/
chunkielad
just got a PDF off www.dynojet.com that is specific to the GS but it still leaves it open at the end saying if it's lean do this, if it's rich do that - how do you know if it's rich or lean?
Also is it worth it in the long run, should i not just go for a better bike?
Ropehead
PostPosted: 00:53 - 07 Mar 2003    Post subject: Reply with quote
have a search for gs500 airbox mod on google loads of good stuff Wink
https://www.nightrider.com/biketech/carbadjust.htm
https://www.ngkntk.co.uk/tips/firing.htm
https://www.ngkspark.com.au/spark_plug_analysis.htm
https://www.eric-gorr.com/techarticles/sparkplugs.html
Doddmaster
PostPosted: 08:11 - 07 Mar 2003    Post subject: Reply with quote
The GS Twin forum is the best place to ask for jetting advice
https://www.gstwins.com/forum/
PostPosted: 09:09 - 07 Mar 2003    Post subject: Reply with quote
Remember you won't goet massive amounts of power from such things, it would probably give you the 'edge' over another gs, but not muich more than that.
G1_
PostPosted: 11:59 - 07 Mar 2003    Post subject: Reply with quote
Oi, G...when you gonna update your avator Razz
PostPosted: 11:32 - 08 Mar 2003    Post subject: Reply with quote
Been meaning to for agggeeeesss (crap wheelie anyway Smile ).... got some gmkd footage last night I might use Smile
PostPosted: 11:49 - 08 Mar 2003    Post subject: Reply with quote
To do the job properly means setting the bike up on a dyno with an exhaust gas analyser to tell you exactly how rich / lean the mixture is at those revs / throttle position / load
The last post was made 23 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 73.23 Kb
