gsx 600f handling question
nick605300
PostPosted: 02:04 - 25 Oct 2005    Post subject: gsx 600f handling question Reply with quote
is this bike a "heavy handling bike i had to really push on the bars to get it to lean and it almost felt like the bike was fighting me ...
is this normal i know the katana guys can tell me i just bought the bike... thanks
McGee
O RLY?
PostPosted: 02:13 - 25 Oct 2005    Post subject: Reply with quote
Should get a GSXR if you want the bike to handle.
LoL i test rode one before my Gixxer they seem to be abit lumpy and a bit heavier than the Gixxer. And naturley there not gonna handle like a sports bike are they and dont expect fantastic qualities either.
Its pronounced Jixxer!
colin1
Captain Safety
PostPosted: 02:22 - 25 Oct 2005    Post subject: Reply with quote
I recently passed my test and test rode a few bikes
the gsxf 600 handled about the worst of the lot
but as long as you got it cheap that shouldnt matter too much
they are ok in straight lines and the engine has plenty of power for overtakes even if its not as good as a proper sports 600
Davo
Davo To The Rescue!
PostPosted: 02:52 - 25 Oct 2005    Post subject: Reply with quote
I've had one of these follow me on a track and he didn't appear to have any problem going around corners. May be worth double checking tyres are at optimum tyre pressure.
colin1
Captain Safety
PostPosted: 02:53 - 25 Oct 2005    Post subject: Reply with quote
a good rider may be able to keep up but it doesnt mean the bike is easy to handle
nick605300
PostPosted: 03:44 - 25 Oct 2005    Post subject: Reply with quote
I realize that this is not the worlds greatest bike but i like the looks and to commute to work and the rides on the weekends this will work great i agree that the tires could be the issue...
colin1
Captain Safety
PostPosted: 03:55 - 25 Oct 2005    Post subject: Reply with quote
even if the tyre pressure is as it should be, if the tyres are worn without the bike being leant over much, the tyre will square off making it harder to lean over
i doubt its the tyres but you will get used to the handling
sickpup
Old Timer
PostPosted: 05:28 - 25 Oct 2005    Post subject: Reply with quote
Shouldn't have any handling problems at all if the bike has decent tyres at the right pressure.
As these are budget bikes people tend to fit budget tyres. Not sure what the later ones take but the early ones take cross ply tyres, use Bridgestone battleaxe BT45 on the front and an Exedra rear and you should be fine. Never use an exedra front on these.
bazza
PostPosted: 14:44 - 25 Oct 2005    Post subject: Reply with quote
Probably better off with BT020s for mixed use. As for handling, you don't want a twitchy, oversensitive sprots bike for commuting.
Unless, of course, you intend spending your time in BCF alternating between posts about your bike's fantastic performance/fantastic handling/fantastic race can/fantastic tarty anodised {$PART_NAME} and posts about your latest crash/near crash/big off/little off/encounter with dozy driver/persecution by police/wheelie/stoppie/dog-poo-avoiding manoeuvre/caught in rain horror story, yadda, yadda, ad infinitum... Rolling Eyes
In which case you need to get a gixxer thou ASAP.
colin1
Captain Safety
PostPosted: 14:46 - 25 Oct 2005    Post subject: Reply with quote
personally id have a big scooter or trailbike for commuting but each to their own
bazza
PostPosted: 14:58 - 25 Oct 2005    Post subject: Reply with quote
Yeah, but you're just a test pilot. Laughing
Bendy
Mrs Sensible
Might be worth checking the suspension settings, you never know if a previous owner has decided to have a fiddle.
Haynes etc should tell you what the standard settings are meant to be, if you're bike's not standard then try returning it to the standard settings then making your own adjustments.
colin1
Captain Safety
PostPosted: 15:14 - 25 Oct 2005    Post subject: Reply with quote
im a test pilot who tested out bikes for commuting and bought a big scooter for commuting type stuff
for commuting i tried a freewind,gsxf600,dominator,yp250 and burgman 400. i liked the yp250 best as it is nippy and agile with just enough power to pull away nicely but still be economical to run
i have yet to decide on what fun bike to get to replace my rs125, if i replace the rs125 at all
bazza
PostPosted: 21:58 - 25 Oct 2005    Post subject: Reply with quote
COLINWALL wrote:
im a test pilot who tested out bikes ... and bought a scooter
And that, m'lud, concludes the case for the prosecution...
Ichy
PostPosted: 00:17 - 26 Oct 2005    Post subject: Reply with quote
What year is the bike? Because of the build quality the rear shock can wear out fairly quickly, luckily its easy to replace, a few other bikes share parts. Same with the front end, changing the fork oil and replacing with 10 or 12w stiffens it up a bit without spending much. There's a post somewhere on setting up the suspension and its worth the effort. If your considering changing the tyres then BT45's or Lasertec work well, roughly £150 a pair fitted.
Not sure how much experience you've got, or what bike you've moved from? I tended to have heavier bikes in the past so the GSX600f didn't seem to bad to me and I have on a few occasions ground out the foot pegs without any concerns. Guys I've swapped bikes with have mentioned that it feels top heavy which has stopped them leaning it over, all down to confidence.
Bike is fine for commuting, reliable with plenty of torque and easy to filter with experience. It will never be the fastest on the road but once you get used to the poor brakes and the noises it makes it can still be fun trying to beat all the sports bikes.
At the end of the day its a bike, its yours, enjoy it.
colin1
Captain Safety
PostPosted: 03:05 - 26 Oct 2005    Post subject: Reply with quote
if you had tried a yp250 you certainly wdnt have bought a gsxf600
or if you wanted a 600, you could have got a thundercat for not much more
but for commuting you are better off with a trail bike or big scooter
the defence rests your honour
as for it being heavy, the vfr750 is heavier but handles much more nicely
bazza
PostPosted: 13:48 - 26 Oct 2005    Post subject: Reply with quote
True.
I'd have put my head in the oven because of the shame. Don't get me wrong - scooters are a perfectly acceptable form of transport...
...if you're female, gay or 16 and saving up for a proper bike.[1]
[1]Disclaimer: E&OE. This comment does not necessarily reflect the writer's views and is inserted purely for comedic effect and should not be interpreted as a character slur on females, gays or impoverished 16-year-olds. If, however, you're Jamie Oliver, then it applies particularly to any fat-tongued, faux-cockney cnuts who might be reading this.
colin1
Captain Safety
PostPosted: 13:56 - 26 Oct 2005    Post subject: Reply with quote
i know some ppl dont wanna be seen on a scooter and for a while it made me wonder if i wanted one.
If i had decided I wanted the image of a bike for around town, I would have had a big trail bike like dominator or freewind.
They handle really well at low speeds, are the comfiest bikes I have ridden. The only thing that put me off was no fairing so not comfy on the motorway and not as economical as the scooter. The dominator handled better than the freewind but had annoying vibration.
bazza
PostPosted: 14:46 - 26 Oct 2005    Post subject: Reply with quote
We have different criteria; I need a bike to commute, tour 2-up and occasionally hoon round the wonderful Welsh roads. This means:
a. Compromise and get 1 bike to do all 3.
b. Buy a different bike for each activity.
c. Buy something which is good at one thing and crap at the other 2.
I chose a. Thumbs Up
colin1
Captain Safety
PostPosted: 14:59 - 26 Oct 2005    Post subject: Reply with quote
i know u love your gsxf600, but you could try a thundercat if you ever fancy a change
i think you would find it can do everything your gsx600f can but a bit better IMO (if im honest a lot better)
vfr750 is also good if you fancy something more comfy for longer distances
you can get either for £1500 both the same insurance group
i am tring to think of this not as dissing someones bike, but broadening their horizons
McGee
O RLY?
PostPosted: 15:39 - 26 Oct 2005    Post subject: Reply with quote
If i had to get around cheaply and not be botherd if it got stolen wrecked etc.
I would get a scooter Wink
sickpup
Old Timer
PostPosted: 16:23 - 26 Oct 2005    Post subject: Reply with quote
What like take a GSXR750 or 1100 motor if you want high performance or share the same parts over a broad range of bikes and years so 2nd hand parts are never a problem. Or wear cheap tyres unlike most 600's. Or be a good crasher due to the almost total covering of the bodywork and lets not forget the cheap insurance.
I am trying to think of this not as dissing someones idea's, but broadening their horizons. Laughing
Zimbo
PostPosted: 22:56 - 26 Oct 2005    Post subject: Reply with quote
If the bike is difficult to deflect from a straight line and the tyre pressures are to spec, it's a case of altering the steering geometry, either by raising the back or dropping the front, or probably both!
Adjust the rear preload to compress the rear shock spring a little more, this will raise the back end a little.
Slacken off the front yoke pinch bolts and drop the bike at the front so you get a bit more fork leg showing above the top yoke (say, 10mm extra). Adjust both the same, and make sure the weight of the bike is supported so it doesn't drop all the way down the fork legs!
You should find the bike turns a lot easier aster that.
bazza
PostPosted: 23:08 - 26 Oct 2005    Post subject: Reply with quote
I don't think it would be that much of a change, TBH.
I'm sure you mean well, but you had a gsxf for an hour or so and base your opinion on that. I've done 14,000 miles on mine since April this year so I reckon I know the bike a little better... Laughing
I'm pretty sure the next bike will be a 900 or bigger...
colin1
Captain Safety
PostPosted: 23:19 - 26 Oct 2005    Post subject: Reply with quote
I had a 98 r1 for an hour and that handled better than a thundercat
only £2500 but Im not sure I shd get it as a first bike although I loved it more than anything else I have tried out.
you cant know whether the thundercat is better or not unless you try it, or by how much
the good thing is whatever you try after the gsxf600 will feel better
in the same way that everything i try after my rs125 feels powerful
if you love your gsxf600 then its not like you have to get a better bike, but there are better bikes be it 600 or 900
it could be that as im used to a rs125, i prefer something thats agile so its a style of ride preference as i know some people prefer something that feels solid and stable
I would say if you do get another bike at some point, its worth doing a few test rides
i know ppl are shy about doing test rides but I think they are invaluable
The last post was made 20 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 128.12 Kb
