| EDBANGER |
 EDBANGER World Chat Champion
| instigator |
 instigator Super Spammer
| EDBANGER |
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 17:22 - 28 Oct 2005 Post subject: |
piston changed every 10-15,000 miles, with new rings. The headlights are shite, so don't think the battery is dead if they seem poo. The sidestand has been known to be a bit iffy on the old pre '98 extrema models. Make sure it has plenty service history, and recipts for everything...
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
 Posted: 17:54 - 28 Oct 2005 Post subject: |
Depends whose manual you read but they say check the rings from 6000km upwards (think newer manuals specify 8000km, which is 5000 miles). To check the rings properly means a top end strip so you may as well replace them. I am inclined to replace the piston as well with every other set of rings.
Finish is generally not bad.
The side stand works very well but there have been some that have broken ( including breaking the frame where it mounts). I suspect that this is from people who sit on the bike with the stand down (just like sitting on a bike on the centre stand tends to wreck them).
Electrics seem basically sound. Be more worried about owner bodges and aftermarket alarms here.
Brakes can be very very good but the standard pads result in a fair amount of lever pressure being required (possibly deliberate choice for a bike aimed at the inexperienced). EBC HH pads work very well but make the brakes very sharp.
Speedo drives seem to fail alarmingly often on newer bikes.
Check the forks for signs of corrosion. Check the rear shock has not peed out all its oil (they are a pathetic attempt at a shock absorber).
Check it the power valve is fitted and if it works. They are often seized in place if left restricted or run around town a lot.
Clutch cables are a total pain to replace. Check for any fraying near the lever and use it as a bargaining point.
The metal bracket that the back of the tank pivots on can break off. No idea why.
Biggest problem will be owner abuse. Check for accident damage, rubbish modifications, screwey jetting, dodgy aftermarket exhausts that rot away in front of your eyes, power valve put in upside down, claims of a racing plug adding 200hp, bald tyres, worn brake pads (they eat pads anyway, my third front set are almost worn out in 18000km total), knackered steering head bearings, seized rear suspension linkages, blown fork seals, etc.
| colin1 |
 colin1 Captain Safety
| Mongrel |
 Mongrel Scooby Slapper
The last post was made 20 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
