kickstart help
bikerboy1
PostPosted: 12:00 - 10 Mar 2003    Post subject: kickstart help Reply with quote
i have a aprilia rs125r 98 model, what is the best way to warm the bike up alot quicker? and where on the rev counter should the bike be sitting at?
when you see something like a bullet going past you, don't worry it's only me!!!!
Scotty
Scooter Boi
PostPosted: 12:18 - 10 Mar 2003    Post subject: Reply with quote
if its running to cold, try covering up the radiator with some ductape
or similar, only like 10% of the area, that should run the bike a bit warmer.
Havent a clue "where it should sit right" in the rev range.
Maybe newbie might be able to help you out with that one...
Regards
Scott
PostPosted: 12:24 - 10 Mar 2003    Post subject: Reply with quote
Do you mean where it should sit when: its idelling over? or when its warming up (choked), or where you should sit it in the range when riding it?
MarsBar
PostPosted: 13:01 - 10 Mar 2003    Post subject: Reply with quote
I tend to sit on the seat, but I have an NSR so it may be different Laughing
TiN
Pocket Tin
PostPosted: 15:21 - 10 Mar 2003    Post subject: Reply with quote
Stephen wrote:
Do you where it should sit when
Question
<on topic> I dunno about 2-smokes, but my RVF sits at 2k when the choke is on, and about 1.3-1.6k on idle.
TiN
dotgems.net
Scotty
Scooter Boi
PostPosted: 15:32 - 10 Mar 2003    Post subject: Reply with quote
Well the NSR once warm should be about
1,400 + - 100
on choke in the winter when it was covered in snow, it once went up to 5'000 on choke.
but normally its about 3'000 on choke till it slides off down to about 1'700.
i supose it will be a similar rpm on the RS, as long as it doesnt cut out then its fine.
Regards
Scott
PostPosted: 17:57 - 10 Mar 2003    Post subject: Reply with quote
Embarassed Embarassed fixed my post now Smile
My NSR was about the same as scotty's, and I cant see there being much difference between them and the RS (other than quality Razz )
ZX I was told to sit it at about 4k with the choke, and i think its about 1.2k without the choke
M1ke
Ped Boi
PostPosted: 19:45 - 10 Mar 2003    Post subject: Reply with quote
mine idels at 1.5rpm now that keith adjusted it for me Smile before it was just cutting out.
Like scotty said a bit of ductape or tin foil over about 10-20% of the radiator, it will warm up quicker. Watch the temp though because on a warm day it may cause it to over heat so be careful.
keith said anything over 130 degrees is dangerous... it should be running in the 80 degree region under normal conditions
PostPosted: 23:39 - 10 Mar 2003    Post subject: Reply with quote
For the idle speed something of around 1200~1500 should be about right. I dont worry too much abou the actual revs, just that it is happy to idle at those revs for quite a while
For the temp, about 80 is normal on an RS. If it goes much over that then start to get concerned. If it gets to 120 then get really worried.
On mine I just start the engine and ride off almost immediatly, but keep the revs down to below 5000ish until it has got up to full temperature
PostPosted: 23:42 - 10 Mar 2003    Post subject: Reply with quote
What sorta temo should my ZX be at, or not going much above for general riding and long distances?
PostPosted: 00:07 - 11 Mar 2003    Post subject: Reply with quote
Not sure with the ZX. It is probably around the 80~100mark, but best read the manual. Does it even have actual temperature markings in the temp gauge?
PostPosted: 00:10 - 11 Mar 2003    Post subject: Reply with quote
Its a digital temp gauge Razz Cool
I aint got the manual yet, on of the bits i forget which is currently someone around G's flat
bikerboy1
PostPosted: 01:02 - 11 Mar 2003    Post subject: Reply with quote
thanks everyone Very Happy
bikerboy1
PostPosted: 01:06 - 11 Mar 2003    Post subject: Reply with quote
also my coolant is funny aswell, i mean do u ever run out of it? because i haven't had to full it up all this time i have had the bike.
Doddmaster
PostPosted: 08:02 - 11 Mar 2003    Post subject: Reply with quote
Coolant doesn't really get used up, so it only needs topping up very occasionally
Demonic69
The Pink Rhino
PostPosted: 11:58 - 11 Mar 2003    Post subject: Reply with quote
Unless you own my RF Very Happy
I dunno where mine Idles cuz the rev counter only starts at 3k Very Happy
Back on a Blade. Just feels so right.
M1ke
Ped Boi
PostPosted: 12:22 - 11 Mar 2003    Post subject: Reply with quote
coolant doesnt get used up as all it is used for is to cool the engine if it gets too warm (so it gets re-used). The only reason it would go down if by either evapouration (would take a long time) or a leak of some sort.
Scotty
Scooter Boi
PostPosted: 12:35 - 11 Mar 2003    Post subject: Reply with quote
Or leaking into the cylinder and being burnt up muhahaha, which will cause all dorts of problems.
Doesnt it need changing every so often..?
Make sure you got some good old anti freeze in there.
dont want it too freeze and crack the block...
Regards
Scott
Demonic69
The Pink Rhino
PostPosted: 12:59 - 11 Mar 2003    Post subject: Reply with quote
I have no temp-guage and my bike's oil cooled. What do I put in the RAD??
PostPosted: 14:22 - 11 Mar 2003    Post subject: Reply with quote
Your GSXR does not have a radiator, it is an oil cooler Rolling Eyes
Demonic69
The Pink Rhino
PostPosted: 14:39 - 11 Mar 2003    Post subject: Reply with quote
Wow! Symantecally sexy all the same. What oil goes in the oil cooler?
Robby
Dirty Old Man
PostPosted: 16:27 - 11 Mar 2003    Post subject: Reply with quote
the oil from the engine flows around the oil cooler. when you do an oil chage the oil will all come out and when you top it up it will top up the oil cooler too.
so no separate oil.
Demonic69
The Pink Rhino
PostPosted: 17:00 - 11 Mar 2003    Post subject: Reply with quote
Cooool Very Happy At least it's slightly more idiot proof (needed) Very Happy
The last post was made 23 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 116 Kb
