erm..a few questions that will probably make me sound stupid
hazza
PostPosted: 21:06 - 01 Nov 2005    Post subject: erm..a few questions that will probably make me sound stupid Reply with quote
ok i have an rxs 100 and it is great!...but when you back off the throttle it makes popping noises...what are they? the engine runs great but makes these weird noises! and would the indicator lights come on but not flash because of a flat battery?
PostPosted: 21:22 - 01 Nov 2005    Post subject: Re: erm..a few questions that will probably make me sound st Reply with quote
Probably an air leak in the exhaust system somewhere. Either at the header or where it joins the silencer.
Probably not. More likely that the flasher relay has died or the bulbs in the flasher are of too low a wattage.
ZRX61
Victor Meldrew
PostPosted: 21:23 - 01 Nov 2005    Post subject: Reply with quote
It's little bubbles popping caused by the amount of detergent used in modern fuels. They float down the exhuast & pop when they hit the sharp edge of the baffle...
All 4 indicators ain't flashing: bad ground or duff flasher unit.
Less than 4: blown bulb
hazza
PostPosted: 21:54 - 01 Nov 2005    Post subject: Reply with quote
the baffle has been cut down because it snapped off when i tried to remove it....i changed the indicators to some cool aftermarket ones but the origanals didnot flash either...so does that mean it would be the flasher unit?
Finglonga
PostPosted: 21:56 - 01 Nov 2005    Post subject: Reply with quote
or your using too much REDEX! Mr. Green Mr. Green
Andy Sez....
F.Y.Y.F.F.
ZRX61
Victor Meldrew
PostPosted: 01:03 - 02 Nov 2005    Post subject: Reply with quote
Probably.. go with an aftermarket one, they only cost a couple of quid.. If ya hit the tit & ya don't hear it clicking it's buggered.
brown_d9
PostPosted: 08:29 - 02 Nov 2005    Post subject: Reply with quote
On my NS125F the idicators stopped flashing and just stayed on and i fixed it by giving the battery a good charging overnight, give it a try, as for the popping thing i dont have a clue.
The last post was made 20 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 52.04 Kb
