| GBUK101 |
 GBUK101 Scooby Slapper
| instigator |
 instigator Super Spammer
| GBUK101 |
| Bezzer |
 Bezzer World Chat Champion
| GBUK101 |
 Posted: 23:07 - 01 Nov 2005 Post subject: |
Will have a look tomorrow. Is that a difficult thing to do, remove the tank? I'm a bit of a novice with the mechanics etc  |
| Bezzer |
| GBUK101 |
 Posted: 23:20 - 01 Nov 2005 Post subject: |
Thanks, will check ASAP. I also filled the tank up tonight aswell  |
| instigator |
 Posted: 16:28 - 02 Nov 2005 Post subject: |
Easy to lift off the tank on an er5 mate, but there IS a nack to it and that's negotiating the fuel tap between the bike's frame and the engine block. It is difficult and brute force is required. You have to twist it around and streth the pipes to do it.
If you haven't go a hanyes manual, I suggest you get one as you have to remove 1 or two lines from the fuel tap.  |
| GBUK101 |
| Bezzer |
| GBUK101 |
 Posted: 20:21 - 02 Nov 2005 Post subject: |
Thanks, I think I will do that. This is really pissing me off  |
| Bezzer |
 Posted: 13:31 - 03 Nov 2005 Post subject: |
Just a thought and something you would be able to check if you've got a manual- how many hoses come from the tank/tap 2- fuel and vacuum or 3- fuel,vacuum and breather. Have the garage put them back on wrong?, if you've got a manual it will show you what goes where and you should be able to follow them to make sure. Some bikes have 3 or more hoses and they can be mixed up letting the bike run after a fashion, used to get it regularly with carbed Blackbirds. ____________________ I used to be indecisive but now I'm not quite so sure. |
| GBUK101 |
 Posted: 13:59 - 03 Nov 2005 Post subject: |
Try running it with the petrol cap open. If there is a blocked breather, this will make the bike run properly. If it is not a blocked breather, this will make no difference.
Sounds like some sort of fuelling problem anyway. Possibly even water in the fuel? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| GBUK101 |
| Bezzer |
 Posted: 15:14 - 03 Nov 2005 Post subject: |
You'd have to drain the carbs and drain and flush the tank. I've just had another thought but this one is a bummer - you said earlier your tank was full. Did the problem start after you filled up, you did put the right stuff in didn't you??? not diesel I hope or then again following on from Stinkwheel duff unleaded containing water. It's not unknown for water in the stations tanks if they are low or for them to fill the tank with the wrong fuel. If it's a garage you use regularly, have a word to see if there has been any other problems. ____________________ I used to be indecisive but now I'm not quite so sure. |
| fredsredhat |
 fredsredhat Traffic Copper
| GBUK101 |
| Bezzer |
 Posted: 23:02 - 03 Nov 2005 Post subject: |
.That's OK then, time to wait then take it back to the "mechanic I think  ____________________ I used to be indecisive but now I'm not quite so sure. |
| GBUK101 |
| the grim reaper |
 the grim reaper World Chat Champion
| GBUK101 |
 Posted: 19:26 - 04 Nov 2005 Post subject: |
Spoke to the mechanic this morning and he thinks that it's either a blocked fuel pipe or a trapped fuel pipe. Arranged to go this afternoon but only managed to get about a mile before the bike conked out Now the thing won't start at all, probably a flat battery. This is really begining to piss me off.
EDIT: Borrowed a battery charger of a mate and the battery is charging away. |
| DanceLikeAMon... |
 DanceLikeAMon... World Chat Champion
| GBUK101 |
 Posted: 13:02 - 05 Nov 2005 Post subject: |
I took it to Cramlington Motorcycles for the service. And he was brilliant
Got the AA out this morning and they managed to get the bike running again, the AA bloke then followed me up the road just to make sure it was running ok. I got to exacltly the same place as yesterday and it conked out again. So out comes the trailer and he towns me to Cramlington. Get's to the shop and the AA bloke has a word with the owner who takes the bike into the back and starts examineing it. To cut a long story short the carbs had pulled a load of petrol through into the engine (about 3-4 litres) which had mixed with the oil and filled up the engine almost completely. All the oil/petrol mixture had to be drained and the oil replaced. Well the bikes running fine now, you woundn't have thought a few hours ago it was not running at all.
Without doubt if you live in the tyneside area I would reccomend Cramlington Motorcycles without hesitiation. A top notch job, great value and excellent customer service. |
The last post was made 21 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
