What is...
Darkside
PostPosted: 21:02 - 04 Nov 2005    Post subject: What is... Reply with quote
An ignition advancer??? Embarassed
https://www.facebook.com/p/Francis-Lloyd_Cummings/630915297
https://www.r1-superbike.com
0ddball
PostPosted: 21:09 - 04 Nov 2005    Post subject: Reply with quote
It advances your ignition.
ZXR750L
PostPosted: 21:16 - 04 Nov 2005    Post subject: Reply with quote
In what context?
In a Pantrher 650 it is a means of starting the bike without breaking your leg.
In a CB125 it is mechanical device that forms an integral part of the points system that means the timing is appropriate for the rev speed.
Bolted to the flywheel of a fireblade it is a device for gaining a few bhp at increased risk of detonation in your engine.
Darkside
PostPosted: 12:00 - 05 Nov 2005    Post subject: Reply with quote
thank you. er and when a bikes been on a dyno what does that mean?
White Noise
Mr Dudwee
PostPosted: 12:22 - 05 Nov 2005    Post subject: Reply with quote
the bike its put on a dyno machine + rolling road and run and various positions through the rev range. the machine tells what BHP/torque the bike is producing at a certain RPM. Also the exhaust gases can be analysed to see it the bike is running too lean (too little fuel in the fuel air mix) or too rich (too much fuel in the fuel air mix) at different RPM.
WN
Teaman
PostPosted: 14:42 - 05 Nov 2005    Post subject: Reply with quote
when the piston hits top dead centre the spark fires,
if you retard it, it fires after, on its way down, if you advance it it fires before.
or is it the other way around?
it alters the fuel efficiency and power delivery...
i know this is a car page but its about what you need to know
https://www.miata.net/garage/KnowYourCar/S10_Timing.html
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Chriss
PostPosted: 15:12 - 05 Nov 2005    Post subject: Reply with quote
I think I understand it now, it creates a higher pressure as it ignites it earlier (forcing the gas upwards reducing the area.)
Is momentum the only reason why it doesn't start going in reverse?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Jack_Cheese
PostPosted: 16:01 - 05 Nov 2005    Post subject: Reply with quote
Yeah, if it wasn't for the angular momentuam of the crank, the engine would go in reverse. I guess since momentum is proportional to speed, the ammount by which it is advanced is reduced at lower revs.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 18:58 - 05 Nov 2005    Post subject: Reply with quote
Exactly. Buy that man a drink.
If you advance the ignition too far on a 2-stroke, it does start running in reverse. First thing you know of it is when you let the clutch out and the bike shoots off between your legs Laughing
Certain immature individuals have been known to do this deliberately then give their mates a shot Whistle
Jack_Cheese
PostPosted: 14:33 - 06 Nov 2005    Post subject: Reply with quote
Reminds me of a conversation in another forum where someone bump started their aprilia rs in reverse! Thumbs Up Mr. Green
Jack
The last post was made 20 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 67.54 Kb
