Got myself a little something..
mchaggis
PostPosted: 17:40 - 05 Nov 2005    Post subject: Got myself a little something.. Reply with quote
Something VT500 shaped in fact. Smile 1987, 50k miles for £450.
Good : The engine sounds sweet as a nut (no smoke, rattles or taps and with a very good condition Motad) Smile , the head, swingarm and wheel bearings seem to be in good condition with no notchiness or freeplay, the tyres have plenty of life left, the brakes feel pretty sharp, the frame is manifestly unbent and not rusty. All the electrics worked fine and it started on the button with a different battery.
Bad: It needs the fork seals doing, a new battery, the rubber on the grips and footpegs is suitably worn, some of the body work is loose (a broken tab or two), the seat is a bit spongy, there's a little superficial rust on the shaft tube. They're supplying the fork seals and battery in the cost of the machine. A few weekends worth of work I guess.
https://pictures.autotrader.co.uk/ATD_web/servlet/media?id=237353436
https://pictures.autotrader.co.uk/ATD_web/servlet/media?id=237353441
https://pictures.autotrader.co.uk/ATD_web/servlet/media?id=237353444
A little tidying up here and there and then it should be all hunky dory. A nice fixer upper. Thumbs Up
I must not be a troll...
Mmmm, Guinness
yzf750r
PostPosted: 17:42 - 05 Nov 2005    Post subject: Reply with quote
Not my thing but at £450!
You dont get much now a days but looks OK for 18 YO! Thumbs Up
The jobs dont sound much neither! Cool
Nath
PostPosted: 18:10 - 05 Nov 2005    Post subject: Reply with quote
Ditch the headlight fairing and do something about the sidepanels, because they're well ugly.
Not bad for less than 500 squid Thumbs Up
Hard livin', hard luck.
strag
PostPosted: 19:04 - 05 Nov 2005    Post subject: Reply with quote
Looking at the pictures you got a good deal mate. Everything 'dodgy' sounds superficial and a great little runaround.
carbon bling
quik_d
PostPosted: 12:40 - 06 Nov 2005    Post subject: Reply with quote
the headlight is part of that "era" of biking, they all had one and (IMO) it suits it, taking it off and putting something else on will ruin it, again only my opinion
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
PostPosted: 12:45 - 06 Nov 2005    Post subject: Reply with quote
Retro cool I think they call it!
phat! Cool
quik_d
PostPosted: 12:53 - 06 Nov 2005    Post subject: Reply with quote
yea, that'll do, the retro look, Cool Cool
PostPosted: 13:20 - 06 Nov 2005    Post subject: Reply with quote
Nice one Thumbs Up looks tidy. I have always liked comstar wheels too. You see a lot of couriers on those things so they must be comfy and reliable.
They have an enclosed front disc don't they? Keep an eye on it, the 'out of sight, out of mind' syndrome tends to occur and next news you have no brakes.
bish777
PostPosted: 14:17 - 06 Nov 2005    Post subject: Reply with quote
I had a 1986 XBR500 with the same comstars, i must admit i have a comstar fetish.
GSXR1100J
TL666
PostPosted: 14:53 - 06 Nov 2005    Post subject: Reply with quote
Nice little bike. Looks perfect for winter and if you sell it when the weather picks up you should even make a few quid on it.
mchaggis
PostPosted: 18:34 - 06 Nov 2005    Post subject: Reply with quote
I could design an enclosed disc brake from scratch if I had to. That doesn't mean I've the first idea about maintaining and looking after them -> they're a complete unknown entity. Laughing
The reason I was taught to use enclosed discs was for applications where they get splattered with water, crap and corruption, and normally not on vehicles which are capable of over the ton. Tractors, road rollers, bulldozers, tanks, that sort of thing. Laughing
Mmmm, Guinness
PostPosted: 18:40 - 06 Nov 2005    Post subject: Reply with quote
Far as I know they are just the same as normal ones maintainance wise. Just you can't see them so the first sign something is not right is when it breaks.
mchaggis
PostPosted: 18:53 - 06 Nov 2005    Post subject: Reply with quote
I could be getting confused with a multi-plate enclosed disc and a conventional disc just covered in a drum. I could have sworn I've seen the enclosed multi-disc type mentioned with regards to a VT500 Thinking Oh well, the Clymer manual will be here soon enough.
Mmmm, Guinness
yambabe
PostPosted: 00:19 - 07 Nov 2005    Post subject: Reply with quote
I've got one like that!
Hints and tips......
Watch out for the electrics, the fuse boxes are rare as rocking-horse poo.
Check your radiator regularly for rust, blockages and holes. The slightest thing and they are prone to overheating. Keep an eye on the water temperature sender at the bottom of the radiotor too, as they can rust and break off.
Check your tank at the bottom, they rust/hole here and can leak. We got a leak in ours, took it off and replaced it temporarily with the tank off one we had bought for spares whilst the other half fixed the leak, only to find that the other tank sprang a leak in the exact same place.
Other than that they are a good, solid, reliable bike. Have fun!
Oh, apparently you can take the dust cover off the front wheel with just 3 screws and this will enable you to check the discs & pads for wear. Bit harder to get at them if they need replacing, but apparently pads last a long long time as they are very big.
/EDIT: There is a chap in Preston who has a shedload of VT500 parts available, pm me if you want an address/phone number.
The last post was made 21 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 83.85 Kb
