Curious thing yesterday
Visitor Q
$25 whore
PostPosted: 10:58 - 07 Nov 2005    Post subject: Curious thing yesterday Reply with quote
Right as you may know, im on the smod while im at uni.
Yippee, when it starts its usually vaguely happy, when and if it starts that is.
Anyway yesterday, with the aid of some bad language i got it started. Slowly riding to give the ancient leviathon a chance to warm up.
Go to overtake a learner a little later. Drop one, clutchless to go up to the next gear... and nothing. Thought id stripped the clutch. Clutched in and booted it again and it worked, albeit dodgily.
Ok, abit cold me thinks, or i cocked up the change.
I carry on, another learner. So i do the same, drop a cog, rev the tits and go to clutchless. Nothing. This time no amount of clutching and shuffling gets it in any gear. So i roll to a stop (deja vue of the cbr clutch stripping).
But when i got it into neutral, and then into first it was fine. There was plenty enough to power wheelie happily, and later on clutchless went fine?
WTF?
The chain was abit flappy and unlubed at that point, but i cant see that making the entire gearbox die.
Or does it?
PostPosted: 11:15 - 07 Nov 2005    Post subject: Reply with quote
I would suggest a sticking clutch cable, but you are doing clutchless changes so that probably counts that out.
It is possible to get a neutral between gears (in theory there is one between every gear, otherwise you could engage 2 gears at once and lock the gearbox solid, but it should be impossible to find them). Few worn gearbox components can make this happen.
I would try doing an oil change and check what comes out with the oil.
Visitor Q
$25 whore
PostPosted: 13:41 - 07 Nov 2005    Post subject: Reply with quote
Could be keith.
Also its got a hydraulic clutch, which i bled recently (albeit badly) and so i doubt it would be a sticking cable.
Oil could be a possibility, but im in the habit of clutchless gearchanges when overtaking (alot easier, although ive noticed if it doesnt move and you do it hard enough you can wobble the bike Shocked but small price) as its alot crisper accelerating.
I was thinking it was perhaps the chain? When i say it was a bit flappy, i mean dame thora hirds boobs flappy. Slight rattling from it on the ride home as well (uber stretching from combination of leaving it outside in the rain unlubed and then doing lots of wheelies and burnouts im sure Embarassed). It was so bad i actually motivated myself to buy some chain lube and tension the bugger.
Was bizarre aswell as it felt literally like the clutch wasnt re-engaging. But then using the clutch i dropped it back into neutral, back into first and slowly pulled away (hill start) and then powerwheelied (to check).
No problems. And later on as i say im sure i did a fair few clutchless changes. I also reved it to the limiter and it didnt feel as if it was slipping...
So is there anyway the clutch can jam up momentarily? But then work itself loose just by gear and clutch waggling?
Thats whats confusing me, inconsistent problems.... Neutral
PostPosted: 14:00 - 07 Nov 2005    Post subject: Reply with quote
Doubt it is the clutch as you haven't touched it prior to cause the problem.
See if any nasties come out with the oil.
satans_BIG_helper
PostPosted: 14:16 - 07 Nov 2005    Post subject: Reply with quote
i would say a oil change check n see what comes out, my TDR does that some times when i do the clutchless shifting Rolling Eyes it pisses me off cos its usually when im about to humiliate some bellend on his shiney R1 on the twisties round here Laughing ah well
Deffo check the oil.... n another thing i used to do to check me gearbox was not have the engine running and gently rock bike back n forth while shifting through gears see if u find any false neutrals that way.... might just be worn internal parts
Jack_Cheese
PostPosted: 20:55 - 07 Nov 2005    Post subject: Reply with quote
Sure you haven't got any air in the pipes? By the way, what bike is your sewing machine of death?
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
mchaggis
PostPosted: 21:56 - 07 Nov 2005    Post subject: Reply with quote
Jack
An old VFR750. There's a video with it in in the Videos section somewhere.
I must not be a troll...
Mmmm, Guinness
Visitor Q
$25 whore
PostPosted: 00:00 - 08 Nov 2005    Post subject: Reply with quote
Sneaky suspicion thats down
Im gonna edit this post with an attachment fingers crossed.
NY_Sniper
PostPosted: 02:10 - 08 Nov 2005    Post subject: Reply with quote
lol ive had that happen and hear from my m8s it happening all the time its the neutrals between gears my zxr has them everywhere when it wants lmao and the gs i belive has one lurking in there as ive hit it a few times nothing to worry about i belive its due to the teeth being knocked about a bit and when u go to shiff u just miss the shift and it leaves it in limbo Razz so i wouldnt worry if i was you
That Dot On The Horizon .... Its Me
> Kawasaki ZX7R (Betty Jnr) <> Suzuki GS500e in pieces (Bitch) <> Suzuki GS500e (Martha) <>
Gazdaman
I did a trackday!!!
PostPosted: 13:32 - 08 Nov 2005    Post subject: Reply with quote
To get a working VFR750 for £300 it must be a real dog!
I think you must have had a bit of a blinder of a deal there, what's insurance like?
Gaz
Visitor Q
$25 whore
PostPosted: 14:26 - 08 Nov 2005    Post subject: Reply with quote
Gaz
Well originally it was gonna be about £300.
Then we said well give £500 to it, but take the mot out of it.
Mot came to about £450, so we were nice to give the guy an extra couple of hundred. So it ended up costing me £700 Crying or Very sad
Last time i ever listen to my dad Evil or Very Mad
It was his mates bike you see.
As for insurance, same as the cbr so just swatted em over.
The last post was made 21 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 76.45 Kb
