Rear brake lever/pedal
MikeyC
PostPosted: 11:48 - 07 Nov 2005    Post subject: Rear brake lever/pedal Reply with quote
Coming home on the dual carriageway the other night, pressed the rear brake lever, and it didnt come straight back up immediately as per usual?
Could this be a sign my brakes need changing?
the grim reaper
PostPosted: 13:10 - 07 Nov 2005    Post subject: Reply with quote
Maybe more likely that you've got a fluid leak and you've emptied the reservoir. You really should spot that kind of thing though Shocked
Grim
MikeyC
PostPosted: 16:23 - 07 Nov 2005    Post subject: Reply with quote
Brakes are fine though, there's been no change there, just the speed in which the pedal comes back up? Confused
map
Mr Calendar
PostPosted: 16:45 - 07 Nov 2005    Post subject: Reply with quote
MikeyC wrote:
Brakes are fine....just the speed in which the pedal comes back up? Confused
Could it just be crud in the linkage/spring on the artual lever? Is the brake light affected then as well? Suggest giving a clean through and seeing if it improves. Failing that, it could be the slave cylinder needs a clean.
Guest
PostPosted: 17:03 - 07 Nov 2005    Post subject: Reply with quote
Crud in the pedal pivot I guess - remove, clean and re-grease.
The last post was made 21 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 43.52 Kb
