My bike stops at idle when it's hot
Joey Bane
PostPosted: 16:09 - 07 Nov 2005    Post subject: My bike stops at idle when it's hot Reply with quote
when my ped is hot after i have driven up a hill at slow speeds and high revs the engine stops when it's idling.
what is the cause of this?
is it the carb heater?
this is sometimes annoying if i have to go off the ped in order to get up a very steep hill and it stops. then i have to hold the brake use full speed select neutral and start it again.
or is it a seizure?
Currently driving: Motorhispania RYZ(yes i'm another ped "boi")
-Savage-
PostPosted: 16:35 - 07 Nov 2005    Post subject: Reply with quote
what "ped" do you have? and what exactly is wrong? does it only cut out on a hll or all the time when its hot and ideling? How long does it take before you can restart it?
Joey Bane
PostPosted: 16:46 - 07 Nov 2005    Post subject: Reply with quote
i can restart it immediatly, but it cuts out if i not keep the revs..
look at my sig. it's got the Motori Minarelli AM6 engine.
18_stuart_88
PostPosted: 18:10 - 07 Nov 2005    Post subject: Reply with quote
Has your Ped got a chock? If so have you left it out, that somtimes causes it to cut out! If not then i think theres sumthing rong with your bike Razz
Stu
Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Smile Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue Mr. Green
Pic of My New Bike!!
Joey Bane
PostPosted: 18:24 - 07 Nov 2005    Post subject: Reply with quote
it's got a choke on the handlebars, but you must hold it in to use it.
Cog Head
PostPosted: 19:09 - 07 Nov 2005    Post subject: Reply with quote
check the choke cable going into the carb, i was washing my bike underneath the fairings and i must have lifted the choke cable and it started but then cut out when i stopped giving it revs, id check that first just make sure the cables are all in the wholes properly Thumbs Up
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
18_stuart_88
PostPosted: 19:10 - 07 Nov 2005    Post subject: Reply with quote
Soo your not leaving it on by accident then and driving off?
Other than that i cant see why it would just clonk out on you
*Scratches Head*
Im sure sombody on here will know Rolling Eyes
Stu
Cog Head
PostPosted: 19:17 - 07 Nov 2005    Post subject: Reply with quote
dose it run when the engine is cold in the morning ?
if so what speed dose it tickover at ?
LUXY DJ
PostPosted: 19:43 - 07 Nov 2005    Post subject: Reply with quote
choke stuck or idle screw not turned up enough Confused
GSXR750
Joey Bane
PostPosted: 20:01 - 07 Nov 2005    Post subject: Reply with quote
it runs when it's cold and when it has cooled down while i drive..
it's just like it looses power, when idling, it don't calm down slowly to idle.
simon1221
PostPosted: 21:03 - 07 Nov 2005    Post subject: Reply with quote
Sounds like its too rich to me, the float needle in the carb could be stuck or wrongly set up, has it always done this?
-> Do you need to use the choke to start it?
Joey Bane
PostPosted: 11:05 - 08 Nov 2005    Post subject: Reply with quote
when it's cold.
it has always been like this
simon1221
PostPosted: 15:52 - 08 Nov 2005    Post subject: Reply with quote
Either:
-> Turn up the idle speed screw so it idles faster
-> Find out the idle mixture screw standard setting (find a manual), or turn it one way or the other so it does idle when hot.
Cog Head
PostPosted: 16:58 - 08 Nov 2005    Post subject: Reply with quote
where can yopu find the idle screw on the Minerelli AM6
as i think that my bike idles a trad high at 2,000 RPM sometimes higher
Joey Bane
PostPosted: 18:05 - 09 Nov 2005    Post subject: Reply with quote
the standard is one and a half rev. i will try.
Gazdaman
I did a trackday!!!
PostPosted: 13:05 - 10 Nov 2005    Post subject: Reply with quote
You don't drive a bike. You ride a bike.
Will the bike tick over at any other times?
It could be a problem with enough fuel getting into the float bowls, going up a hill at high revs is using up all the fuel. Althoug that's very unlikely.
Gaz
Joey Bane
PostPosted: 11:45 - 30 Nov 2005    Post subject: Reply with quote
it happened before i derestricted it to: when i rode up a hill wide open on low revs
The last post was made 20 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 90.86 Kb
