| JaZ |
 JaZ Guest
| Richard |
 Richard Guest
| JaZ |
 JaZ Guest
| C Samsgard |
 C Samsgard Guest
| JaZ |
 JaZ Guest
| C Samsgard |
 C Samsgard Guest
| JaZ |
 JaZ Guest
| Tony |
 Tony Guest
| milo |
 milo Guest
| Keith |
 Keith Guest
 Posted: 05:57 - 15 Nov 2001 Post subject: Poorly NSR |
Hi JaZ, I live in Stafford so drop me a note on <A HREF="mailto:100662.3423@compuserve.com">100662.3423@compuserve.com</A> and we will meet up and I will have a look. I will have to check if I am insured to ride someone elses bike though. A lean mixture means that there is not enough fuel for the air, and rich mixture means there is too much fuel for the air. The mixture should be (about) 14.7 parts air to one part fuel, by wieght. A SLIGHTLY richer mixture gives best power, and SLIGHTLY leaner mixture gives best emmisions. Run too rich and the plug will get coked up and the bike will not give good power. Run too lean and the engine will run hotter, give less power and stand a chance of seizing or burning a hole in the piston. As Milo mentioned, how old is the plug? To check the mixture (roughly) you can do a plug chop. Find a steep hill (one from Weston on the A518 is probably a good one) and hold the bike on full throttle at high revs up it. When ready, pull the clutch and hit the kill switch at the same time. When you get to a halt take out the plug and have a look. It should be a nice biscuit brown colour, too dark and it is rich, too light and it is lean. Also, how many miles has it done? It may be worth thinking about new rings if it is around 10,000. Maybe worth running a compression check on it, but only if someone else can confirm a healthy reading to compare it with. It is almost certainly a good idea to clean out the air filter. The air filter should be lightly oiled, but that means only a tiny amount and it will work fairly well with no oil on it. However, it seems stange that the bike runs quite well in 5th, but then looses power badly in 6th. All the best Keith |
| Chris |
 Chris Guest
| JaZ |
 JaZ Guest
| Chris |
 Chris Guest
| Keith |
 Keith Guest
| JaZ |
 JaZ Guest
| Keith |
 Keith Guest
| JaZ |
 JaZ Guest
| Keith |
 Keith Guest
| JaZ |
 JaZ Guest
| Hibby |
 Hibby Guest
| JaZ |
 JaZ Guest
| JaZ |
 JaZ Guest
 Posted: 19:11 - 19 Nov 2001 Post subject: hmmn power valve. |
ok, the thing that turns when u start up, well, it turn once when i press ignition, then when i give some start the engine it turn again, but it does look at times as tho its tryin to move (makes a pathetic whimper of a whirrr) but turns about 1 mm. ive put my air/fuel at 3. will go out for a spark test in a minute. couldnt find a red - thite connection in the wirin box under tank. couldnt find orange - white under rear faring. theres a few suspect connections tho.. hidden down the side. dunno tho. im gonna full her up with premium, get some shit hot 2stroke, warm her up for half hour at least, then see if theres any difference. im worried bout this powervalve tho, its poorly. but the bike runs, and i get power at 8k. sluggish till then tho. thx for all the advice peeps =) JaZ |
| JaZ |
 JaZ Guest
The last post was made 24 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
