NSR125 startup Problem
Deluce
PostPosted: 11:42 - 09 Nov 2005    Post subject: NSR125 startup Problem Reply with quote
HI all
I have a hondaNSR125, that don't seem to want to start in the cold
or when left for 2 days or so without a run
I have a new battery and spark plug
I went to a friends house and left the bike out side in the cold for about 1hr
when I went back to it, it would not start
any ideas ?
THX
the grim reaper
PostPosted: 12:22 - 09 Nov 2005    Post subject: Reply with quote
Check that your regulator/rectifier is charging the battery, even a new battery will drain without being charged when you ride. Ideally you need a multimeter, you're looking for about 14.5 V across the battery when the engine is revved.
A cheap check is to see if the lights get brighter when you rev the engine. This doesn't necessarily mean that the reg/rec is healthy though, it may be putting too much voltage across the battery which will also fry the battery.
Grim
knockout_bar
PostPosted: 12:36 - 09 Nov 2005    Post subject: Reply with quote
Ummm, are you trying to start it without the choke?
125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) Thumbs Up
alains
PostPosted: 13:52 - 09 Nov 2005    Post subject: Reply with quote
i agree with you , but it will be more efficient to upjet the carb , especially the slow jet . i had this problem in the past which i solved partly by putting the choke on after having stop engine . but changing my 38 slow jet by a 42 made the trick . the late models are really underjet (132,38,55) , the best is to fit 138,42,65 for £10 ish
Deluce
PostPosted: 14:53 - 09 Nov 2005    Post subject: Reply with quote
no i had it on full and then half,,, did get it going but took some time.
i also put lights on for a second to see if the bat was ok,
and lights was ok.
Could it be my choke? not set right or somthing
alains
PostPosted: 15:03 - 09 Nov 2005    Post subject: Reply with quote
clean carb & tank (tap also), air filter foam , change your jets , fit a BR9EIX and it will be ok
Deluce
PostPosted: 15:06 - 09 Nov 2005    Post subject: Reply with quote
Good man THANKS for the quick reply and INFO
i will give it a go ASAP
P.S whats a BR9EIX (im a bit new to bikes) Embarassed
THX
alains
PostPosted: 16:24 - 09 Nov 2005    Post subject: Reply with quote
this is a race plug . they are expensives (£6.84 ex VAT) but very efficient and will save 1/2 to 3/4 L on a full tank
https://www.sparkplugs.co.uk
generaly i fit a BR9EIX this time of the year and the BR10EIX in hot days or if i run mainly on motorways
WizardofNos
PostPosted: 20:07 - 09 Nov 2005    Post subject: Reply with quote
I have that problem but luckily it stopped it from being stolen !!
I found the problem was because I always had my lights on! every were I went.. even short journeys.. it kill's a crap Batt..
I hope it's not a repost!
Deluce
PostPosted: 05:32 - 13 Nov 2005    Post subject: Reply with quote
Thanks again for the great info,, not had time to do it all yet,
but did have time to pop to town and buy a optimate charger
when I first plugged it in to charge, it said the bat was very discharged
so left it charging till full
then went on a 30min ride with lights on
got back home and left the bike stud for about 2hrs and the plugged the charger back in and the bat was badly discharged again?
so could my start up problem be electrical?
also when I put the brake lights on the front light dim by about 20%
even when travailing at 60mph
Sad
True Blue
PostPosted: 09:16 - 13 Nov 2005    Post subject: Reply with quote
Sounds as if your battery isn't being charged properly when your out riding Confused
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Aikman666
PostPosted: 10:23 - 13 Nov 2005    Post subject: Reply with quote
How long have you had the battery? All of the recent cold weather may have helped kill it so it has a smaller capacity than usual.
Will work for petrol
My Design Blog
alains
PostPosted: 10:45 - 13 Nov 2005    Post subject: Reply with quote
it seems that your battery is worn , buy a new one (less than £20)
download this file from my ftp
https://www.geneva-racing.com/~alains/NSRtips.doc
you will find studies on the batteries
Deluce
PostPosted: 11:02 - 13 Nov 2005    Post subject: Reply with quote
had the same problem on and of for months now,
and got a new bat about 2 months ago Sad
P.s thanks for the FTP file,,, Razz
very useful
gamerboy
PostPosted: 23:45 - 13 Nov 2005    Post subject: Reply with quote
where you from deluce?
tokarev
PostPosted: 23:50 - 13 Nov 2005    Post subject: Reply with quote
Make sure that you are using the right battery. The NSR uses a YTX5L-BS.
If you are using the incorrect one, then it may not me able to gain charge from the system.
Deluce
PostPosted: 02:28 - 14 Nov 2005    Post subject: Reply with quote
Thanks for that,, i will have a look Wink
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 93.49 Kb
