| Psychonaut |
 Psychonaut Spanner Monkey
| fuzz |
 fuzz World Chat Champion
 Posted: 13:26 - 09 Nov 2005 Post subject: |
Leave yourself a bigger gap - 4 seconds is recommended in the wet - and brake progressively. Use a little back brake but too much might lock it up. Don't get into the habit of 'I need to brake now, oh shit' yank the lever in, it'll take you longer to stop than squeezing the lever. ____________________ https://www.bikepics.com/members/fuzzbcf/
 Posted: 13:27 - 09 Nov 2005 Post subject: |
It happens, but is something to be avoided. Often the first you will know about loosing the front end on the brakes is when you get up close and personal with Mr Tarmac. Avoid being in the situation where you need to brake that hard.
Not sure how much effect putting you foot down really has. Suspect it has little effect in reality, but is something that would probably be very difficult to avoid doing.
| Psychonaut |
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 13:49 - 09 Nov 2005 Post subject: |
Your clue is in the word 'usually', this means you are expecting something to be the same way it was the day before - bad idea!
FWIW, everyone makes these sorts of mistakes, it's spotting the mistakes and eradicating them from your everyday riding that is the key. Once I've learnt how to do that, I'll let you know
Cheers
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| paulthewitt |
 paulthewitt World Chat Champion
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 16:31 - 09 Nov 2005 Post subject: |
My brake disc is on the left, and the last few times i locked up the front, the bike went to the right. It's not a nice thing to happen to you, but a foot down stops it falling. Either that or the bike takes you with it when you're going too fast. If you get on the back brake first, the worst thats going to happen is the back brake locking which is easy to control, even for a new rider, so i go for 40:60 front:back brake, and gradually increase my front pressure, keeping the pressure on the back brake constant(unless it locks...).
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| gimpy limp |
 gimpy limp Nearly there...
 Posted: 17:40 - 09 Nov 2005 Post subject: |
gotta remember that your back brake is no where near as effective as stopping you as the front is, so I favour the back for that reason and because its easier to control unless I need to stop quick sharpish then its the front and back. Dunno if anyone else gets shown this in their cbt's but my instructor showed us the difference between the 2 and just using the back caused it to stop a good 2 bike lengths more than just using the front. At 30 using the back and front it stopped in a few metres if that. I quite like it when the backend comes out, it's only a matter of easing off the back and following it through, i've had mine out 50 degrees from left to right on really gravelly stuff that i forgot was their  ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
 Posted: 17:55 - 09 Nov 2005 Post subject: Re: Loosing the front wheel in the wet |
| Psychonaut wrote: | Should I be putting my foot down or just try and hand on whilst letting go of the brake. Is this a normal experience I should learn to adapt to (like then the back steps slightly out when you go over a manhole cover in the wet) or something that I should avoid at all costs (much bigger gaps infront in the wet/ride around a problem ) |
Well, you really don't want the front sliding at all, although it is usefull to have an idea of what it feels like so you know what is happening should it occur.
You definately want to come off the brake if you feel the front going. I suppose ideally a bit of power would help transfer the weight onto the rear wheel too, but you were probably braking for a reason so that isn't really very helpful.
Putting feet down, well I think it is hard to stop yourself. On the occasions I have had the 'spider legs', I am pretty sure it helped keep the bike rubber side down. Possibly has the effect of moving the C of G of the bike, a bit like hanging off it round corners? I certainly found that sticking a leg out on my supermoto made it more stable round corners, and easier to control when the front started to wash out a bit.
You see some spectacular footage from some of the superbike/GP racing of someone losing it entirely, getting the big spider legs and saving it against all the odds. I remember someone (forgotten who) highsided a while ago and landed up 'waterski-ing' the bike to a standstill whilst standing next to it, impressed me that did.
I suppose the main thing is the old chestnut, observation and anticipation. If you observe the road and its users and anticipate the circumstances that made you brake, you need never have a slide again. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| doggone |
 doggone World Chat Champion
| Psychonaut |
 Posted: 10:01 - 10 Nov 2005 Post subject: |
Tire wear is fine 2500miles from new I am told that the OEM tyres are crap on the CBR125 in the wet but I've had no trouble cornering in the wet yet. I think its just down to lack of experience, just shocked me how quick it goes without any warning, where as when the back goes is seems more progressive. It feels like you'll never know the fronts about to go until it does  |
| ranna |
 ranna Crazy Courier
| NSR125-Kid-UK |
 NSR125-Kid-UK Attention Whore
| mchaggis |
 mchaggis World Chat Champion
 Posted: 11:24 - 10 Nov 2005 Post subject: |
I locked the front up in the wet last week. Everything bent back more or less into place without too much fuss. You need not even be harsh with the lever, just pull it too hard and it can go down. The brake disc is on the left side of the wheel, the bike fell to it's left, though that might have been a result of my automatic reaction to stamp with my right foot.
Said stamp did nothing but break my big toenail. I have however saved a fall with a boot on several occasions before, so it's not an altogether lost cause. As regards getting off the brake, that is simple common sense. A slippery surface will mean that you need a fair amount more time before the wheel stops sliding though. The best bet is to avoid it all together. ____________________ I must not be a troll...
Mmmm, Guinness
| RealNinja |
 RealNinja World Chat Champion
 Posted: 12:05 - 10 Nov 2005 Post subject: |
 Posted: 12:11 - 10 Nov 2005 Post subject: |
| RealNinja |
 Posted: 12:17 - 10 Nov 2005 Post subject: |
| Kickstart wrote: |
But you avoided it this year at Snetterton .
Keith |
Very true......
https://www.bikechatforums.com/viewtopic.php?t=65544
 ____________________ You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny |
| biggerjohn |
 biggerjohn Spanner Monkey
| beefcake |
 beefcake Nova Slayer
| killa |
 killa Won't Shut Up
 Posted: 16:26 - 10 Nov 2005 Post subject: |
The size of the tyres don’t help either, is that your bike in the avatar?
I would say that the new materials they use on those new bikes are brilliant, but much lighter, I found a lot less slippage on older bikes late 80’s early 90’s because of the weight and thicker tyres.
I’ve had a go on a bike similar to yours, they stop in an instant so progressive is the key!
Trick is to use more of your strength with the bike, don’t let it make you think it is going to quick so you need the brakes, you should be travelling at speeds in the wet that are very comfortable to go around corners using your engine braking using your body more.
Unfortunately shiny tarmac and manhole covers are not your fault, your regular roads should be memorised for this crap, with the roads you are not too familiar with all you do is ‘expect’ things like that.
Don’t freeze up either when you know your on one or cant avoid it, you’ll loose you feel for the road and can sometimes make rigid movements that can, in the end be your downfall. ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| Jack_Cheese |
 Posted: 00:43 - 11 Nov 2005 Post subject: |
I had a nice 2-wheel slide going round a slippery corner going to the pub from which i have just returned, managed to get it sorted though. It would have been fun if i wasn't riding my only form of transport. It has been a hairy day...
| BenBray |
 BenBray Spanner Monkey
 Posted: 04:48 - 11 Nov 2005 Post subject: |
I had the back go earlier - I was going pretty fast around a tight bend... I felt like I was sliding, then realised the bike was no longer pointing exactly where I wanted it to. It wasnt as bad as I thought it'd be.
As for the front going, I've had that twice. Once was a stupid application of front brake on a slow corner [can you say knobhead?]. I pulled the bike back up while sliding my foot on the floor :o Better off stamping me thinks
Second time I was braking and the front of the bike bike just seemed to tip to the right. Somehow saved it - relaxed on the bars, gave it a small amount of throttle, ended up in a nice big lean to the right. Didnt help me to avoid my mates clio in front though
Anything outside of your control is just that - theres nothing you can do about it. Beat the road condition into your head for winter and you should be fine - just slow down  ____________________ Current Bike: nc30 |
The last post was made 20 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
