Headlight Angle
tatters
Exxon Valdez
PostPosted: 19:53 - 10 Nov 2005    Post subject: Headlight Angle Reply with quote
hi guys
Anyone know what the dipped beam hight should be from a fixed distance (ie. on to a wall from a certian distance). bloody cagers keep flashing there headlights at me as if l was on main beam and l,m guessing that the angle is wrong.
Steve H
PostPosted: 08:53 - 11 Nov 2005    Post subject: Reply with quote
From MOT UK
LIGHTS
Of the 20% failure rate on bike MOT tests, over half are for defective lights. Quite amazing since these are amongst the simplest items to check yourself before going to the test.
The requirements are simple, and quite straightforward to replace or adjust, without the need of a mechanic.
HEADLIGHTS & TAIL LIGHTS must be free of chips or cracks; the headlight must also work on main and dip beam, the main beam must shine directly ahead and the dip slightly lower and to the left.
INDICATOR LIGHTS must all flash at a steady rate and the warning lights function properly.
If a HAZARD WARNING SYSTEM is fitted, all 4 indicators must flash at a steady uniform rate.
Bikes must have a red REFLECTOR on the rear of the machine, either bolted on separately or as part of the tail light lens.
Mellow Yellow
The last post was made 21 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 33.22 Kb
