fitting CF reeds
milo
Guest
PostPosted: 03:41 - 18 Nov 2001    Post subject: fitting CF reeds Reply with quote
all i know is tank off (easy) airbox out (easy) but then what?
cheers!
gonna be fitting them this weekend with some luck
Guest
PostPosted: 16:50 - 18 Nov 2001    Post subject: Fitting Reeds Reply with quote
Take off airbox, move carb out of the way. Undo the 4 bolts holding the carb rubber to the engine. This allows you to remove it and the reed block. The reeds are then held in with a few screws (which also hold the reed stops in place). Undo the screws and you can remove the reeds. Put the new ones in and check that they seal correctly. Probably a good idea to use loctite on the screws as you really do not want them to come out.
Then just put it together again
milo
Guest
PostPosted: 06:26 - 21 Nov 2001    Post subject: probs Reply with quote
Well monday morning i go out and proceed to take my bike to bits for the first time, to try to change the reeds. Not knowing exactly what to be looking for. I found the carb (i think, it had all the right inputs!)
I took that out and carried on, looking for these vital few screws but couldn't find them. i thought they were right next to the cylinder, after the carb but i couldn't see anything like that there. there seemed to be a part of the carb where they could be hiding but i thought i'd better leave it there and took some pics to see what you all thought and where i was going wrong.
I saw 4 bolts so i took there off and wow, there was something i reconised, the fuel restrictor. that was promptly removed but can always go back in. the bike's smoother now and has much improved throttle response...and power Smile
a few questions though, where are the reeds?
what are the 3 pipes coming off the carb? and where do they need to be? seem to be breather pipes but leak fuel if they were at the wrong angle, so now propped up against something above the carb.
My bike now doesn't auto-rev with the choke when cold, what have i done wrong?
and are these reeds the same as the ones everyone else got?
Here's the pics to help you, and me!
the 3 pipes:
<A HREF="https://members.tripod.co.uk/freelance_stuff/bikestuff/3_tubes.JPG">https://members.tripod.co.uk/freelance_stuff/bikestuff/3_tubes.JPG</A>
general view of stuff, carb at the bottom of piccy?
<A HREF="https://members.tripod.co.uk/freelance_stuff/bikestuff/input_restrictor.JPG">https://members.tripod.co.uk/freelance_stuff/bikestuff/input_restrictor.JPG</A>
and the reeds i've got:
<A HREF="https://members.tripod.co.uk/freelance_stuff/bikestuff/the_reeds.JPG">https://members.tripod.co.uk/freelance_stuff/bikestuff/the_reeds.JPG</A>
Hope somebody can help!
I'm just suprised the bike's still running. And is it me or does Honda really like using 10mm bolts?!
cheers!
-Adam
Guest
PostPosted: 06:10 - 22 Nov 2001    Post subject: Reeds Reply with quote
The reeds on further into the engine. You can just about see the back of them in the picture "input_restrictor.jpg", through the hole in the middle of the input restrictor
milo
Guest
PostPosted: 14:47 - 23 Nov 2001    Post subject: cheers Reply with quote
cheers m8. now i know where they are i can try to get to them!
but any ideas about the choke probs? kinda annoying as it's getting very cold in the mornings!
The last post was made 24 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 39.6 Kb
