sachs xtc 4 stroke loads of probs :(
Biker_Dene
PostPosted: 10:48 - 12 Nov 2005    Post subject: sachs xtc 4 stroke loads of probs :( Reply with quote
1) just recently once u get the bike started even wen its warm if you rip the throttle right back it will go pop pop pop STALL does it every time what could this be???
its just been serviced
2) every now and then if ur doing 5k or higher revs and you throttle it fast the clutch engaged a little bit and u dont get anywhere it just revs
3) its having problems getting started in the first place i think it could be the coil but not sure i cant really tell you much more about this problem it just wont start.
thanks
Dene
Biker_Dene
PostPosted: 13:05 - 12 Nov 2005    Post subject: Reply with quote
probs 1 and 3 fixed starts every time and doesnt cut out wen u throttle it even wen cold
still got the weird clutch prob tho
bidman
PostPosted: 22:07 - 12 Nov 2005    Post subject: Reply with quote
Problems 1 and 3 were either caused by water in the tank a very common problem with sachs in the petrol cap seal. Also the carb floats seem to stick fairly often, worth checking anyway. For the clutch how many miles have you done are there any wierd sounds when idling at stand still, also what hapens if you get up to 5 k and when it stands messing around pull in the clutch and dump it on 6k revs just to see if it kicks through the problem, let me know how it goes, Dan
Don't ride it, RAG IT!!
Biker_Dene
PostPosted: 14:14 - 13 Nov 2005    Post subject: Reply with quote
hi thanks for the reply
iv done little over 10k kilometres if i rev to 6k and dump the clutch i just pop a wheelie lol
simon1221
PostPosted: 15:01 - 13 Nov 2005    Post subject: Reply with quote
Perhaps change the gearbox oil? I put car oil in my bike and the clutch slipped in the powerband due to 'friction reducing additives'.
Tighten the adjuster on the cable?
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 42.41 Kb
