speedfight fuel tap/filter
seanyboy150
PostPosted: 13:36 - 12 Nov 2005    Post subject: speedfight fuel tap/filter Reply with quote
hi there, can anyone help me. The fuel filter/tap device thats connected directly to the bottom of the fuel tank. theres 2 tubes coming off it. one you can blow through it, and the other one you cant blow or suck through it. the one you cant is connected to the manifold piece thats bolted onto the reed valves, the one that cana be blowed through is connected onto the carb
any ideas? cheers folks
Mr noOdles
PostPosted: 14:51 - 12 Nov 2005    Post subject: Reply with quote
Confused bit confused
the large see-thru tube connects to the carb (fuel line)
the small black tube connects to either carb, engine casing OR carb manifold not sure how it works for peugeots (vacuum pipe)
hope this helps Thumbs Up
Project Typhoon (Abandoned)
Project MegaTyphoon (Under Planning) Arrow www.MyMoped.tk Update will regularly take place on a weekly bases.
zorgman
PostPosted: 19:18 - 12 Nov 2005    Post subject: Reply with quote
av a look at the pipes where they go onto the carb, one should go to the side of carb and should go to the top connector on pet tap
the other pipe which is the one u can suck and blow thru will go to the front of carb and connects to the top of the petrol tap
bidman
PostPosted: 22:22 - 12 Nov 2005    Post subject: Reply with quote
the pipes should be slightly different sizes so it should be fairly straight forward if not, i'm pretty sure the vacuum 1 will be the 1 that connects to your manifold for the suction and teh other fuel into the carb Thumbs Up , Dan
Don't ride it, RAG IT!!
seanyboy150
PostPosted: 11:09 - 14 Nov 2005    Post subject: Reply with quote
yeah just found out that ones a vacuum, that connects to the manifold and only acts as valve when the engines running. the other one connects staight from the fuel tank to the carb.
cheers!!!
The last post was made 21 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 43.55 Kb
