Nasty noise on idle
MikeyC
PostPosted: 09:26 - 15 Nov 2005    Post subject: Nasty noise on idle Reply with quote
Like a very loud 'ticking' kind of nose coming from the front of the bike, the radiator it sounds like. It first starts after i've been riding about 5/10 mins, whenever I stop.... if I rev it gently, sometimes the ticking noise stops, other times it doesn't. Weird..... Thinking
Claud 14.7 to 1
PostPosted: 09:58 - 15 Nov 2005    Post subject: Reply with quote
I pretty sure these Gixers had a know issue with the cam-chain (some had to be returned for fixing) . Not sure if what you have is a symptom of the chain failing.
I doubt it's the valves. Anything loose around in there? Have a look.
the grim reaper
PostPosted: 10:17 - 15 Nov 2005    Post subject: Reply with quote
How many miles on the bike? If it only starts tapping when warm, it could be valve clearances. These should be checked at 16k miles and again at 32k miles.
Grim
MikeyC
PostPosted: 10:30 - 15 Nov 2005    Post subject: Reply with quote
I had a service on 18k and they were checked then, its now on 26k.... hopefully its nothing too major, im skint! lol!
alains
PostPosted: 17:04 - 15 Nov 2005    Post subject: Reply with quote
when was your last piston change ? do you know that every 7500 miles you need to de-carbonize the top-engine and :
- 7500 miles rings exchange
-15000 piston exchange
it seems that your piston is worn and you must feel a loss of power , remember the nsr has a special coat in the barrel which is far more harder than the rings and piston .
iCraig
PostPosted: 18:08 - 15 Nov 2005    Post subject: Reply with quote
I think he has a problem with his GSX-R600 and not the NSR!
alains
PostPosted: 18:23 - 15 Nov 2005    Post subject: Reply with quote
i misunderstood , sorry !
bidman
PostPosted: 19:05 - 15 Nov 2005    Post subject: Reply with quote
Hi, may sound a little stupid but i had a gsxr 600 in for repair the other week because he had a rattle coming from the engine and thought it was cam chain, but all it turned out to be was loose exhaust downpipes rattling around at the mounting points Thumbs Up have a look at yours, Dan
Don't ride it, RAG IT!!
MikeyC
PostPosted: 20:06 - 15 Nov 2005    Post subject: Reply with quote
Bikes going in for its MOT shortly, i'll get them to take a peek Thumbs Up
The last post was made 21 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 57.98 Kb
