Opening your headlight assembly up....
ShiftyCapone
PostPosted: 05:41 - 16 Nov 2005    Post subject: Opening your headlight assembly up.... Reply with quote
Ok, this is for all of you guys that have cracked open your headlight assembly before:
What is the best method to use in order to get your headlight assembly apart? I've heard that the oven is the best way, but I don't know what temp. or amount of time.
Thanks in advance....
Guest
PostPosted: 07:24 - 16 Nov 2005    Post subject: Reply with quote
Why?
the grim reaper
PostPosted: 12:26 - 16 Nov 2005    Post subject: Reply with quote
Assuming you mean the glue that holds the clear plastic to the backing plastic then an oven can be a problem as it heats up everything. I'm guessing that either the lens or the bulb holding part is damaged?
I'd say that hot water would be better than an oven, I've done this once and that worked for me.
Make sure you use a rubber based glue to join the parts afterwards, superglue is too brittle.
Cheers
Grim
The last post was made 20 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 34.58 Kb
