My ZXR 250 c 1991 wont rev past 2k revs...
Groove
PostPosted: 13:06 - 16 Nov 2005    Post subject: My ZXR 250 c 1991 wont rev past 2k revs... Reply with quote
started my bike this morning, eventually and it ran fine for the first km or so.
go around a roundabout and suddenly it doesnt like to rev. i had to keep a low gear and keep it above 10k jus to keep accelerating to 40mph...
Everytime the bike went low revs, ie 3k revs it would cut out. It started again no problem but persisted in doing it.
Start my bike up after lesson (when i got to college) and it did, eventually but will only rev to 2,000 revs (the first notch on the rev counter) this is with throttle fully open! if i let go of the throttle it would just cut out again. Mad
So anyone know any possible reasons for this? theres plently of petrol etc lol.
was working fine yesterday Crying or Very sad
PostPosted: 14:27 - 16 Nov 2005    Post subject: Reply with quote
For goodness sake people, it is not difficult. Do you really think "HELP!" conveys to the reader anything about their likelyhood of assisting you with your problem? Do you know how many threads there are in the workshop section titled "HELP!"? We know you need help, otherwise you wouldn't be posting here.
Also, we are not telepathic. Tell us what sort of bloody motorbike you have.
So a good example of a title would be. something like. "CG125 repeatedly stalls and wont rev up"
[/rant] (sorry you copped it Groovearmada but I get pissed off)
As to your problem. Sounds like fuel starvation, could be a number of things such as: Blocked filter, blocked fuel tap, blocked fuel line, blocked needle valve, blocked main jet. I'd work through them in roughly that order.
Groove
PostPosted: 15:05 - 16 Nov 2005    Post subject: Reply with quote
errrrrrrrrr thanks? lol
thought everone knew what my bike was by now Wink ZXR250 c 1991 Razz
PostPosted: 15:37 - 16 Nov 2005    Post subject: Reply with quote
Carburettor icing would be my suggestion... Smile
PostPosted: 16:51 - 16 Nov 2005    Post subject: Reply with quote
Certaily could be carb icing (which indirectly causes fuel starvation Wink )
Only thing is, I get the impression from the post that you are riding through town. Also, I would have expected it to 'sort itself out' for a bit after being stopped for a while. I would have also expected it to be worse at big throttle openings when there is a high flow of cold air rather than at low revs when the pilot circuit should be dealing with a lot of the fueling.
Groove
PostPosted: 22:59 - 16 Nov 2005    Post subject: Reply with quote
my route:
after the bike started at 10.55am after a struggle for a couple minutes to get it started i revd the engine a bit in an atempt to warm it up. Pulled away and it felt a little slugish but i jus put this down to being cold (didnt have its cover on last night Doh! Embarassed )
Got to the top of the road, a T junction. Stoped fine, idle'd fine. Pulled away to the right still okie dokie and took it to about 12k revs in 1st, 2nd gears and to about 10k in 3rd before sitting around 6k in forth coming to the first round about.
Turn off first exit still OK, took it to about 14k revs through most gears and end up somwhere around 80mph down the bypass. Come to the roundabout everything went tits up. Change down as usual nothing eventful happened. start going round the roundabout to the last exit and it starts struggling to rev. I know ive got plenty of petrol so make sure im in the right gear and continue, just about.
Come to a set of road works, pull clutch in and bike cuts out at 2k revs or so. "oh fuck". Bike starts up with a lovly roar and away i go. Same thing happens once or twice more and again jus parking the bike up Neutral
Well thats my story, i miss riding her already and dont no why this is so long Confused
Ah well, will have a look in the morning, trouble is the bike is still at college. Wont be easy pushing it all the way home, up quite a few hills Mad
Jrod
Page 3 Girl
PostPosted: 10:44 - 17 Nov 2005    Post subject: Reply with quote
I think carb icing aswell.
Robby
Dirty Old Man
PostPosted: 11:17 - 17 Nov 2005    Post subject: Reply with quote
Possibly also battery. You can get funny symptoms with knackered batteries.
Chuck in some pro FST or similar, if that doesn't solve it get the battery on a charger and see if that helps.
Jrod
Page 3 Girl
PostPosted: 13:59 - 17 Nov 2005    Post subject: Reply with quote
If it is the battery it would be wise to check your reg/rec using a multimeter.
paulthewitt
PostPosted: 17:57 - 17 Nov 2005    Post subject: Reply with quote
had a zxr250a nice bikes they are. carb icing...hmm posibly but on mine it wouldnt still be iced when i came out of lesson....id leave it two minutes and itd be fine again...but it did suffer massively with carb icing so get som pro fst...that sorted it out for me.
otherwise blocked lines and clean the carbs are always a good place to start as already suggested....get a fuel filter if you dont have one and check that the rubber hoses are all fine and not corroding on a bike that age, mine were starting to so i changed them....
check the vaccuum taps on properly(or the rubber hose) and that the tubes arent kinked or trapped....had you done any work on it before the problem started? like lifting the tank and takig off the airbox as its easy to trap hoses under the air box as its a pig to put back in...althouh there is deffinately a technique...
cheers
Andy
Groove
PostPosted: 12:29 - 18 Nov 2005    Post subject: Reply with quote
well i put it in the garage yesteray that a mate recommended, i went down there before with a couple mates as they know the bloke well.
phoned up today and it will be somtime next week before i get her back Crying or Very sad
basically, carbs were very dirty (kinda already knew this but did nothing Doh! ) so hes taking them apart and cleaning them.
Think somthing was said about too much petrol going through or somthing and the tap wasnt working properly Brick Wall
oh and there was some petrol in with the engine oil Shocked
Thats the jist of what i was told from my dad who phone him this morning (i was at college)
Looks like a boring weekend for me Thumbs Down Crying or Very sad
The Tot
PostPosted: 13:28 - 18 Nov 2005    Post subject: Reply with quote
Groove, i'd suggest carb icing too. Because i just started my bike and it cut off completely on very cold mornings. Wait for the temperature to rise a bit and it'll be completely fine. I wouldn't have thought it was the battery because i've fully charged the battery yesterday on my ZXR.
Silkolene FST will do the trick nicely and WHEN my bike fires up, i'm off to get a bottle of the stuff.
Never argue with autism
Sparks!
Sir Tart-a-lot
PostPosted: 00:18 - 19 Nov 2005    Post subject: Reply with quote
Take the fake ram air duct things off and tape over the holes left on the plastic tank bit. This was a problem with ZXR400's.. although the fake ram air doesnt really od much it does chuck a lot of air under the tank where the carbs are .. hence carb icing...
Might explain why it rode fine for a while /then/ had the problems?
Try it..
The Tot
PostPosted: 20:29 - 19 Nov 2005    Post subject: Reply with quote
Got my ZXR started and running my dousing the tank full of warm water. Heated the tank a bit, causing a hooting noise (possible fuel vapour) to escape. Thumbed the starter button and it started running fine.
Just to make sure, i added Silkolene FST to ensure that it wouldn't stutter when riding somewhat fast, and it didn't so hats off to FST.
paulthewitt
PostPosted: 14:56 - 21 Nov 2005    Post subject: Reply with quote
those air ducts are there for a reason, to cool the reg/rectifier aparently...it will overheat and possibly blow i was told by a kwak garage that deals with the 250...so i wouldnt block the holes too much just in case...
like i said earlier (i think i did anyway) pro fst works, i tried it with good results on the zxr250 and now others have...buy some...
andy
The Tot
PostPosted: 15:24 - 21 Nov 2005    Post subject: Reply with quote
The hesitence at lights and stuttering has gone somewhat, but starting it up on a cold day is still a bitch. Yes, the battery is charged.
I'd check the spark plugs, but it's a bugger to get to as i'd have to remove the fairing bolts, which have rounded somewhat!
The starter motor will spin up, it's just that the darn thing won't spark up.
Any suggestions?
Btw, i DONT Turn the throttle when pressing the starter right?
Jrod
Page 3 Girl
PostPosted: 16:07 - 21 Nov 2005    Post subject: Reply with quote
It's the 250 not the 400, the 250 has real ram air and doesnt have the plastic bit on the tank if I'm correct?
The Tot
PostPosted: 17:58 - 21 Nov 2005    Post subject: Reply with quote
Jordan, that is correct! I was looking at Riichy's ZXR on bikepics and comparing it to mine and realised the tanks were completely different. My hoover pipes went directly into the tank and not to a secondary piece infront of the tank.
Groove
PostPosted: 19:36 - 21 Nov 2005    Post subject: Reply with quote
Well as this is my thread...
i got it back today, work done:
Arrow Dismantle carbs and clean (he showed me the shit that came out of them after just draining them Shocked Surprised )
Arrow cleaned fuel line and tap.
Arrow new spark plugs
Arrow charge battery
Arrow oil change (had petrol in it Shocked )
Cost: £129.91
Starts up fine, but its running like shit. Basically it has to idle higher or somthing for a few miles so idleing at 2k rpm. He said i could change it back to normal tomorrow or somthing.
But the thing is it really is a struggle to go fast. Takes a year to get to 60 as it revs sooooo slowly and no more than about 11k rpm.
Is this just because of the work done and would sort it self out or was the timing not set right?? Sad
Ill take her out for a ride tomorrow morning or somthing, change the idle speed and if no change i shall take her back.
Groove
PostPosted: 12:47 - 22 Nov 2005    Post subject: Reply with quote
oh dear...
went out there just now to find some rather not nice looking white stuff under my bike, didnt paticuly smell of anything. started her up to see if she would, reved it a few times to see if she could hold herself at 2k revs, nope.
Look under her again and theres what seems to be oil dripping Shocked
Phoned up the garage, must be on his lunch break or somthing as only got the answer machine. Wont risk riding it the mile or two to the garage.
sigh Sad
Groove
PostPosted: 16:31 - 22 Nov 2005    Post subject: Reply with quote
fuck it. Came off the fucker pulling out of a junction. Would take a lot of money to get right, specially as it wasnt right in the first place Mad Evil or Very Mad Evil or Very Mad Shocked Surprised Sad Crying or Very sad Evil or Very Mad Neutral Middle Finger Evil or Very Mad Middle Finger
paulthewitt
PostPosted: 16:51 - 22 Nov 2005    Post subject: Reply with quote
barton will prolly buy it for £300 - £400...part from that fix it...i dont know what the white stuff is but the oil is prolly a gasket that i doubt the garage could have knackered by the list you gave...
sounds like gaskets would help ... petty is getting in the oil (somehow) hmmm
Groove
PostPosted: 17:08 - 22 Nov 2005    Post subject: Reply with quote
got a quote that the garage could get it fully back to working order for £600...
Shocked
it needed new piston rings or somthing
Whos barton?
The last post was made 21 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 133.96 Kb
