Polishing out scratches??
-Savage-
PostPosted: 13:30 - 17 Nov 2005    Post subject: Polishing out scratches?? Reply with quote
Here is my headlight, it has some scratches in it which i presume were obtained from a low speed spill befor i bought the bike.
Can i sand/polish them out? wet and dry? anyone tried this before?
fuzz
PostPosted: 13:52 - 17 Nov 2005    Post subject: Reply with quote
I think if you try and use anything even slightly abrasive you'll end up making things worse. I'm no expert, but unless you want a full on frost effect, anything you try will compound matters.
Walloper
PostPosted: 15:11 - 17 Nov 2005    Post subject: Reply with quote
To remove the scratches you will have to remove the glass to a level below the deepest scratch. It can be done by polishing with fine grain abrasives, but by machine. (Or you will have nil sex life for a month.)
Buy a new lens simple.
Rookie
PostPosted: 21:09 - 17 Nov 2005    Post subject: Reply with quote
It could probably be done with a mechanical buffer, but I expect the hassle of getting it there and the cost of having it done would outweight the advantages of just getting a new one. Chances are it won't look perfect.
Keep an eye out on eBay for CBRs being broken maybe?
Knowlsey
PostPosted: 22:24 - 17 Nov 2005    Post subject: Reply with quote
Take it to a car windscreen shop, they will polish it out, or try and get some jewellers rouge (rocky horse shit)and a dremmell with polisher
Bendy
Mrs Sensible
PostPosted: 22:36 - 17 Nov 2005    Post subject: Reply with quote
You can't see the headlight when you're on the bike, so what's the problem? Smile
Jack_Cheese
PostPosted: 00:19 - 18 Nov 2005    Post subject: Reply with quote
The finest wet + dry on earth, used with water. Then coarse rubbing compound, then fine rubbing compound, then T-cut, then more, and more, and more, and more T-cut. Followed by so much polishing, you'll feel like you've just recreated you whole youth's worth of masturbation in one hour. Have fun! Mr. Green
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
kawakid
PostPosted: 01:08 - 18 Nov 2005    Post subject: Reply with quote
Try Brasso
I've a twin and a 4.
Rookie
PostPosted: 01:22 - 18 Nov 2005    Post subject: Reply with quote
Easy for you to say Bendy! Wink
ZRX61
Victor Meldrew
PostPosted: 03:53 - 18 Nov 2005    Post subject: Reply with quote
Thats a step in the wrong direction... I've polished scratches out of aircraft windshields.. we use 15,000 grit....
BanditsHigh
Worse than a woman
PostPosted: 08:05 - 18 Nov 2005    Post subject: Reply with quote
Easy ... 1200-1500 wet'n'dry ... rub it down using plenty of water until the surface of the scratch is smooth.
If you have a buff and polishing compund then use that for quickness (only polish for a second or so at a time to stop melting the plastic).
The other way is to use T-Cut and then Brasso ... you should be able to get a very good finish.
All the best ... Barry
Jack_Cheese
PostPosted: 17:32 - 18 Nov 2005    Post subject: Reply with quote
Shocked where does one acquire such heavenly material?
Would work wonders on my paintwork!
Jack
Walloper
PostPosted: 20:17 - 18 Nov 2005    Post subject: Reply with quote
25,0000,000,00 grit wet or dry is what you need to use at 178,000,000.5Hz. For about 1 1/2 hours with 15lbs of pressure.
That should shift it for you.
Not too technical for you?
ZRX61
Victor Meldrew
PostPosted: 00:21 - 19 Nov 2005    Post subject: Reply with quote
Jack
Wouldn't even make a mark on paint, I usually get it from aircraft part supply companies.
All ya need for paint is 1500 & then hit it with a power buffer.
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 79.24 Kb
