Something very worrying has happened
Slinn84
PostPosted: 20:00 - 18 Nov 2005    Post subject: Something very worrying has happened Reply with quote
Ok coming home from uni today on the thundercat and i was going down a straight road so i thought i'd strech her legs a bit, doing 90mph at 9000rpm and i closed the throttle to slow down a bit and after a second or so heard a loud crack coming from the rear of the bike.
thinking i'd just gone over a loose man hole cover i carried on
the same thing happened again going up another road tho soon after, high revs, close the throttle and another loud crack (getting worried now)
when i got home i had a look round the back at the exhaust and could smell something burning coming from the silencer, not the normal exhaust fume smell either, something more sinister. there was also a strong smell of petrol in the garage after i parked her up for a bit
there's no petrol leak from the pump, hoses or tank so i'm assuming something engine wise has occured
any ideas? is this just my bike backfireing? if so whats the cause
i'm really at a loss of to what is cuasing this cos the bike has been behaving perfectly lately
cheers
Bezzer
PostPosted: 21:18 - 18 Nov 2005    Post subject: Reply with quote
Coming off the throttle is when you get carb icing if your bike suffered from it as the idle circuit is affected. Would have been ultra cold at 90 I'd guess it's on the edge of icing as you've slowed down but not fully affected, got a bit of excess fuel and you ended up with a bit of a backfire....that is just a guess, see if it happens again
PostPosted: 23:26 - 18 Nov 2005    Post subject: Reply with quote
Chain adjustment?
ThunderSteve
PostPosted: 23:27 - 18 Nov 2005    Post subject: Reply with quote
Shocked
Same thing happened to me yesterday morning on the way to work.
Was doing about 70 though, checked the cat over at work, did not see anything obvious. So the sugestion of carb icing makes most sense to me.
I bought some lead replacement fuel additive this morning when I filled up, added some and no icing to or back from work at all. Not even the dreaded slow down and get iced.
All the best.
Steve
Slinn84
PostPosted: 00:18 - 19 Nov 2005    Post subject: Reply with quote
ok
Chain adjustment?
how might this make the cracking noise? i've adjusted my chain anyway just incase.
how do i avoid carb icing then?
cheers for the info guys
Bezzer
PostPosted: 00:52 - 19 Nov 2005    Post subject: Reply with quote
1. Slow down.....a lot Laughing
or
2. Dunno but should your bike have electric or coolant carb heaters? if so check they're working, not blocked etc.
or
3. Forget 1 and 2 and just get some Silkolene Pro Fst additive and start adding it to your petrol, that'll cure it.
Slinn84
PostPosted: 01:12 - 19 Nov 2005    Post subject: Reply with quote
nice one beezzer i'll give it a try
can anyone else vouchfor this stuff?
i've heard of all kinds of additivies for petrol but always been warry of them, after all engines are designed for petrol, so i assume that nothing else should get in them but i'll try it out
cheers guys
Bezzer
PostPosted: 01:45 - 19 Nov 2005    Post subject: Reply with quote
It's THE cure dude, anyone who has used it swears by it, causes no problems and it WORKS. .
https://www.socweb.co.uk/forum/forum_posts.asp?TID=30891&PN=1
[url][/url]
PostPosted: 12:26 - 19 Nov 2005    Post subject: Reply with quote
Loose chain smacking into the swinging arm / rear hugger.
Difficult. You can use additives to the fuel. Ride at about 20mph max. Block off the cold air intakes to the airbox, forcing it to get air from around the engine. Covering part of the radiator to for it to be a bit hotter helps. Check it a carb heater kit is fitted (often something that is not fitted to parallel imports).
However not sure how this would make a cracking noise. It is water vapour that freezes in the carbs and that isn't going to make it go bang. More likely that if it is the exhaust making a cracking noise then it is cause by an air leak in the exhaust.
Slinn84
PostPosted: 12:48 - 19 Nov 2005    Post subject: Reply with quote
an air leak in the exhaust? sounds likely now, there's a small rusted hole in the downpipe where the 4-2-1 goes from 2 to the link pipe. could this be the cause?
it happened again today, does'nt happen all the time tho, and only at high revs, simply solution i suppose is not to rev her too hard.
cheers
PostPosted: 14:41 - 19 Nov 2005    Post subject: Reply with quote
Air leaks tend to cause backfires in the exhaust.
Get some GumGum and plug the hole up and see if that fixes it. Might not last long but will at least let you know if that is the problem.
NSR Mick
PostPosted: 16:34 - 19 Nov 2005    Post subject: Reply with quote
might be worth checking the cush drive rubbers
colin1
Captain Safety
PostPosted: 23:14 - 19 Nov 2005    Post subject: Reply with quote
I had this today or something similar when riding through thick fog on my 600. Not very loud but for a sec I was scared cos I thought the tyre had popped Smile
The last post was made 20 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 78.18 Kb
