My "extras" list!
BenBray
PostPosted: 19:58 - 20 Nov 2005    Post subject: My "extras" list! Reply with quote
I'm replacing the following on my marauder 125:
Front Pad [With brake bleeding]
Rear Shoes
Chain and Sprockets
Rear Tire
So, In order to do so I need tools and some other stuff.
AFAIK I need the following, what else do I need?
Correct Tools
Copper Grease [back of pads]
Gear Oil [Or some form of lube for the chain and sprockets]
Grease for Rear Axle [Any specific type for this purpose?]
Brake Fluid
Grease for Rear Axle [What kind of grease exactly?]
Some form of tube for bleeding old fluid [Any advice on whats safe?]
Anything else I need guys?
Thanks for any replies,
Ben
Current Bike: nc30
Biker-Kev
PostPosted: 21:07 - 20 Nov 2005    Post subject: Reply with quote
Fairy liquid for fitting the back wheel
Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license
BenBray
PostPosted: 00:42 - 21 Nov 2005    Post subject: Reply with quote
Not being funny, but where am I installing this back wheel? The sink?
When it comes to serious issues like bike mechanics, I'd rather not have silly answers - just incase I actually did that and lost my legs in a crash.
Current Bike: nc30
Bezzer
PostPosted: 00:56 - 21 Nov 2005    Post subject: Re: My "extras" list! Reply with quote
Rear Shoes
Chain and Sprockets
Rear Tire
Technically he's not taking the piss, you said you're replacing the rear tyre amongst the other things and what do you need. Fairy liquid is home DIY tyre soap and can be used as lubricant to help you get a tyre on the wheel Whistle
BenBray
PostPosted: 01:01 - 21 Nov 2005    Post subject: Re: My "extras" list! Reply with quote
Rear Shoes
Chain and Sprockets
Rear Tire
Technically, he said back wheel not back tire. I dont know anyone that fits and balances their own tire - to me thats more of a professionals job.
To be fair, if someones checking what they need for simple stuff like pads - what makes you think they'd actually be fitting the back tire to the wheel and balancing it all? Wink
Cheers for the help
Current Bike: nc30
Bezzer
PostPosted: 10:56 - 21 Nov 2005    Post subject: Reply with quote
Your bike has spoked wheels I believe?, a tubed tyre?? or at least that's the assumption with a spoked wheel. It's the easiest thing in the world to change a tubed tyre once you've got the knack, it's just an enlarged pushbike tyre when all's said and done. It's certainly as simple as changing pads and chain. And simple to use cheap DIY balancers are readily available.
Everyone used to to change their own tyres until tubeless became the norm on bikes, it's not a black art.
You need heavier duty stuff to do tubeless, bead breakers, a compressor etc but manual operated tools are available fairly cheap so you can do it, there are loads of people out there who do their own after buying them cheap mail order.
bidman
PostPosted: 11:49 - 21 Nov 2005    Post subject: Reply with quote
yeah, use a bit of comon sense mate, Rolling Eyes if your seriously asking us for help in doing such simple jobs, surely you would be better just taking it to a garage Thumbs Up
no offence intended
Don't ride it, RAG IT!!
BenBray
PostPosted: 11:50 - 21 Nov 2005    Post subject: Reply with quote
For the sake of buying the tire at the shop and having them fit it and balence it for free [as long as the wheels off the bike] then I'm not fussed about buying tools I'm only going to use once, or maybe twice.
Anyway... I assume the rest of the list is fine and I dont need anything else ^^
Ben
Current Bike: nc30
Gazdaman
I did a trackday!!!
PostPosted: 12:33 - 21 Nov 2005    Post subject: Reply with quote
Personally I'd get the tyre fitted by a garage. Although I have done a 125 front tyre myself before it's not simple. And if you get it slightly wrong it handles horribly.
Buy a brake bleeding thing from Halfords, costs about a fiver, will last forever, and is excellent. No messing about with loosen > pump > tighten > release > repeat.
Just put this over the bleep nipple, pump away to your heart's content, (topping up the fluid obviously). Once there are no bubbles in the tube, tighten up and Bob's a male relative.
Copper grease for the rear axle, that stuff works wonders. Put it on the threads of any bolts you're putting back in aswell. Chain and sprockets buy some proper chain lube. Although I've never replaced sprockets, I have replaced 2 chains on 2 bikes, beware! They stretch alot in the first 100 miles. Keep a close eye on them, take it easy over that first stretch, and tension as necessary.
Get a wire brush aswell to clean out the rear drum and the insides of the caliper. Force the pistons of the caliper back into their housing aswell. Give it a good clean.
Gaz
Biker-Kev
PostPosted: 20:12 - 21 Nov 2005    Post subject: Reply with quote
You clearly state you are fitting your own tire, nowhere does it say you are getting a profensional establishment to do it, so i gave you advice on what you needed. Okay i said wheel but meant tire asbezzer could see.
You really need to get your attitude sorted out mate[/b]
PostPosted: 23:30 - 21 Nov 2005    Post subject: Reply with quote
Latex gloves/barrier cream. You will be getting brake dust, old chain oil and brake fluid on your hands.
Long straight edge/piece of string to align the wheels.
I find spray brake cleaner does a fantastic job of cleaning out your hub/drum and getting all the shite off it before fitting the new sprocket. Also cuts the cleaning time for your calliper in half. Just remember it will blast grease and oil off places it is supposed to be so you will have to put it back on/in.
Remember to put the split link on the right way round.
mchaggis
PostPosted: 23:59 - 21 Nov 2005    Post subject: Reply with quote
Never did me any harm... Shifty
(Well, nothing that Swarfega, a nail brush and some new skin didn't sort out. Laughing )
I must not be a troll...
Mmmm, Guinness
BenBray
PostPosted: 01:58 - 22 Nov 2005    Post subject: Reply with quote
Accidental double post - hit quote and not edit Shocked
Current Bike: nc30
BenBray
PostPosted: 02:00 - 22 Nov 2005    Post subject: Reply with quote
BenBray wrote:
LOL at the nail brush and new skin Laughing
Thats fair enough - reading back through I stated *I* was sorting it - so thats my fault... I was meant to specify the tire was being fitted by something else. Apologies mate, I was a bit of an arsehole there Thumbs Up
Bidman:
I've only been riding a month or two, and havnt done anything mechanical with my bike. I figured I'd learn how things work etc by sorting the stuff that needs doing on the bike myself. In order to do that I need to know wtf I need and what I'm doing. I'd much rather have people I give me good solid advice, than try it myself and be going down the road with no brakes!
If you're seriously brain deficient enough to understand that people need to learn what they're doing in a new environment, and that some people care about their safety on machinary thats dangerous enough as it is, then I would invest in brain surgery.
No offense intended. Smile
P.S got someone showing me what to do and fitting it all/assisting me for a bit of cash... Really appreciate the help though, thanks a lot Smile
Current Bike: nc30
bidman
PostPosted: 15:01 - 22 Nov 2005    Post subject: Reply with quote
If you were that worried about your safety you would get a garage to do it and if you really wanted to know how your bike worked and how to do work on it, you'd find out for yourself Thumbs Up
The last post was made 20 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 90.13 Kb
