Suggestions?
nsr_boi
PostPosted: 19:24 - 25 Nov 2005    Post subject: Suggestions? Reply with quote
Hi, my DNA125 doesnt start it just makes a clicking noise and i know it isnt the starter motor because i just bought 1? any suggestions PLZ?
Mr.Everready
PostPosted: 19:32 - 25 Nov 2005    Post subject: Reply with quote
battery
nsr_boi
PostPosted: 20:09 - 25 Nov 2005    Post subject: Reply with quote
Npe the battery works fine? Any other ideas PLZ?
Slinn84
PostPosted: 20:11 - 25 Nov 2005    Post subject: Reply with quote
do ya lights come on automatically when ya turn the ignition on?
if so are they still on now? if not dead battery, if they flicker then ur battery is dying
charge ya battery then try again
if the problem persists check ya spark plugs are firing ok
check the fuel supply isn't blocked
check the fuel tank breather isn't blocked
nsr_boi
PostPosted: 20:36 - 25 Nov 2005    Post subject: Reply with quote
The battery works fine bcos the digi clock shows up also the horn works strongly. How do i check if my spark plugs are firing or not?
mchaggis
PostPosted: 21:01 - 25 Nov 2005    Post subject: Reply with quote
Battery: charge it. The clicking is the starter relay.
There is enough charge to switch the relay, but once it makes the connection, the starter motor draws too much current for the relay to stay switched. It disconnects, and there is then enough current to make the connection again. The relay activates, runs the starter motor, which draws too much current, so on and so forth..
I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 45.92 Kb
