Speedo problem on Kwak GT550
funmonkee
PostPosted: 17:41 - 27 Nov 2005    Post subject: Speedo problem on Kwak GT550 Reply with quote
Hi everyone,
I bought a winter hack - a kawasaki gt550. It was cheap and the only real fault is the speedo "stop working a couple of weeks ago"... Anyway I have disconnected the speedo cable from the front wheel and connected it to a drill, turned the drill on and the speedo jumps into action (5 - 10 MPH... yey). So I guess the speedo cable is okay! On the down side this means something must be wrong with the connection at the front wheel (Sorry dunno what it's called....).
Can anyone tell me how I can test this to see if its a problem here or If anyone knows if this is a common fault and how much it's likely to cost to fix??? I'm not too worried about knowing what speed I'm doing as the Winter hack is mostly for in town and I just gauge my speed on other road users (mistake!!!)...but the fact that the mileage isn't ticking on is a MOT problem and when I come to sell in March I don't want to tell the buyer that the mileage is incorrect.
Also is there any other gadget that I can buy (not GPS) that I can use on the bike to tell me what speed I'm doing without connecting to the standard speedo drive mechanism??? Just so I can compare to the standard speedo (this is actually for my Vmax).....
Any help really appreciated Wink
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
mchaggis
PostPosted: 19:34 - 27 Nov 2005    Post subject: Reply with quote
A bicycle speedo (the magnetic pickup type) could be persuaded to the job, you'd get no speedo error either. Smile You should be able to get one for less than a tenner.
The speedo drive (assuming it's the front wheel) isn't especially substantial, it's entirely possible a dog tooth has been bent, (hell, there are only two in my 125 Neutral ) Strip and clean the whole thing and you should be able to tell if anything is busticated.
I must not be a troll...
Mmmm, Guinness
PostPosted: 19:41 - 27 Nov 2005    Post subject: Reply with quote
You can buy digital speedos like you put on pushbikes for about £15.
The bit that is broken is called the 'speedo drive'. Essentially a small gearbox that converts the wheel turning into turning of the speedo cable.
Chances are this bit is ok. There is usually also a small steel tube/ring with two tags that engage into the wheel hub and two notches that turn the speedo drive itself (essentially linking the wheel to the drive). These are made of very thin steel and are pretty flimsy.
Could be worn out or broken. Equally, cack handed removal/replacement of the wheel without lining the tags up properly can buckle the ring or bend the tags over which would just need straightening.
Found a piccy showing these 'tags' on the speedo drive gear:
https://www.hondaminitrail.com/gifs/speedogear.jpg
funmonkee
PostPosted: 20:32 - 27 Nov 2005    Post subject: thx Reply with quote
Cheer guys thats well helpful Karma
The last post was made 20 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 42.58 Kb
