| shakey0465 |
 shakey0465 L Plate Warrior
 Posted: 12:35 - 28 Nov 2005 Post subject: nsr 125 r not running right |
I have just purchaced a 1995 nsr 125r. It seems to have a problem though, I will try to explain as best as i can.
The bike starts fine, revs fine all the way through the range when not riding.
now, when pulling away from a standing start, if rpm below 5000, no problem, ample power in lower rev range through every gear, so nice smooth ride upto 55 -60 mph.
if I do a high rpm pull away 9000 rpm then again no problem until i get to top gear and then you notice the lack in power to keep it there and it slows down to 60 mph.
when riding along at 60 mph I have to drop a couple of gears to get into the high rev range 9000 + before it will go any faster, but it seems to really take it's time to pick up the revs.
I have also noticed that the throttle makes no difference between 1/3 and full except for a deep throaty roar from the airbox.
I have checked out the following so far: exhaust has been derestricted, the plate to restrict the inlet manifold has been removed, the jets are as follows 135 main, 40 slow, 65 power.
the needle has 5 grooves and it was set on the bottom setting nearest the point.
the spark plug is a NGK R BR9ECS
the plug is showing signs of running slightly rich
there has also been 6 holes drilled in the top of the airbox.
this is a uk spec bike
the problem seems to be worse when the bike is warm but it doesn't overheat at all, the temp needle sits just into the norm
Not having owned one of these before i am now stuck as to what is going on, I am sure it is mixture related but it can get expensive stabbing in the dark.
any idea's[/i] |
| alains |
 alains World Chat Champion
| shakey0465 |
| shakey0465 |
| alains |
| shakey0465 |
| alains |
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful? |
