U-turns.Make of this what you will....
Delvard
PostPosted: 13:55 - 26 Nov 2005    Post subject: U-turns.Make of this what you will.... Reply with quote
But it's interesting. I bumped into my old DAS instructor this past week, crackin' bloke get along well with him. Got chatting about tests etc and I asked him if everyone was still failing on U-turns and breaking speed limits (THE most common errors as far as he was concerned). He laughed but went onto tell me that in the past month the examiner here in Plymouth has passed 5 learners that he knows about who've 'dabbed' there foot down when doing a U-turn.
I was really suprised as I'd failed my first test due to not doing a rear observation after completing a good u-turn. I asked what he thought about this apparrent change in rule. He wasn't aware of any change but went onto say so much is down to the examiners perspective of your ability on the day. ie If the rest of the ride, before and after the U-turn is first and foremost confident and displays good rider ability in all other areas, all is not lost if you dab your foot down. It may go down as a minor.
I'm not saying do it Mr. Green but I'm saying all is not maybe lost if you do....
Andy Wink
A thing of beauty is a joy for ever: Its loveliness increases; it will never Pass into nothingness; but still will keep A bower quiet for us, and a sleep Full of sweet dreams, and health, and quiet breathing.
yambabe
PostPosted: 15:28 - 26 Nov 2005    Post subject: Reply with quote
I dabbed my foot down on the U-turn on my first test and only got a minor for it. Failed cos I left an indicator on. Rolling Eyes
KevlarPants
PostPosted: 17:20 - 26 Nov 2005    Post subject: Reply with quote
yeah, my instructor said that one might get away with a dab if you are lucky on the day.
Biker-Kev
PostPosted: 17:59 - 26 Nov 2005    Post subject: Reply with quote
Whats the rear observation after u turn? My instructor has never mentioned it
Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license
Delvard
PostPosted: 18:35 - 26 Nov 2005    Post subject: Reply with quote
When you come to a stop after completing a u-turn you must make a rear observation to see if any traffic is coming. If it is you must put on a left indicator. No traffic, no indicator. I failed my first test for not doing that rear observation.
Biker-Kev
PostPosted: 18:56 - 26 Nov 2005    Post subject: Reply with quote
So is that a look over your shoulder then pull over?
After the U-Turn do you just pull over on the left of the road? My instructor has never mentioned this Sad
Delvard
PostPosted: 19:10 - 26 Nov 2005    Post subject: Reply with quote
You can do a U-turn in one of two ways:
1)Make 2 good rear observations and check for traffic. If all is clear immediately start the u-turn. After completing the u-turn on the other side of the road make a single rear observation as I've described.
2) Make 1 good rear observation, If all is clear you may proceed in a straight line for a couple or so metres to settle your balance. . Before commencing the u-turn you should make a further rear observation. If all is clear commence the u-turn. After completing the u-turn on the other side of the road make a single rear observation as I've described.
The 2nd method is too be avoided if at all possible. By having to make a further rear observation whilst moving your setting yourself up for having to stop if any traffic makes an appearance. You'll then have to start all over again. Going straight into the u-turn is the much prefered method.
Andy Wink
Biker-Kev
PostPosted: 19:14 - 26 Nov 2005    Post subject: Reply with quote
okay cheers mate
ISLAND GIRL
PostPosted: 19:38 - 26 Nov 2005    Post subject: Reply with quote
I have been taught that a dab is acceptable on the U turn, today I went out and did four on four different roads and was 100%, was well pleased.
As for stopping after I have just been taught that you do the rear obs before stopping but do not have to worry bout using the indicator on stopping Mr. Green Feeling better about my test today.
kath600
PostPosted: 12:30 - 27 Nov 2005    Post subject: Reply with quote
probably best to stick with the thought though that its not ok to dab foot in a u-turn tbh.
if you got a minor on the the rest of the test but you think you did ok and didn't worry about dabbing foot thing, then you'd be gutted when you are told you have failed.
i was taught it was not ok to dab foot all!!!
probably helped me to pass first time Thumbs Up
Seven days without laughter......... makes one weak.
mchaggis
PostPosted: 01:09 - 28 Nov 2005    Post subject: Reply with quote
For all the scorn about doing feet up U-turns, the slow control it uses is crucial to a hell of a lot of riding done in built up areas or in congested traffic. As a tool to show that you can ride very slowly under control, it is pretty useful.
As for doing feet-up U-turns on the road, pfft!. Razz Plenty of U-turns, but none feet-up. Why bother? Confused
I must not be a troll...
Mmmm, Guinness
BenBray
PostPosted: 02:26 - 29 Nov 2005    Post subject: Reply with quote
Maybe I'm being soft, but whats your oppinion on dabbing a foot down in dodgy weather conditions? acceptable? I mean if you slip with a slightly hovered foot, you could kick up and save it - and if its wet/potentially quite slippy - it shows you've thought about road condition and potential hazards.
Just a thought!
Ben
Current Bike: nc30
priller
PostPosted: 03:16 - 29 Nov 2005    Post subject: Reply with quote
You foot should be ok the peg not hovering above the ground.
BenBray
PostPosted: 10:26 - 29 Nov 2005    Post subject: Reply with quote
I meant sort of putting your foot almost down at the middle of the turn in case the bike started to slip at all, essentially creating a bit of hover for a little while... meh... just a thought.
Current Bike: nc30
mr.z
PostPosted: 20:23 - 08 Mar 2006    Post subject: Reply with quote
Got to say this is totaly new on me, i know an examiner so i'll give him a call and see what he has to say about it.. makes sense, as long as your in total controll and still make the manouver..
I very nealry failed doing a u-turn, 9/10 i'd do perfect but the first was allways a badun..
If you do mess it up then ask if you can do it again because your nervous and mess up, if they say yes then your ok, if not youve lost nothing (examiners discression with this)
Thing with a u-turn is who here honestly uses it? i allways do a 2-point turn (trying to use the camber or gradiant of the road if i can to roll backwards with feet allong the floor) makeing carefull observations before and during, unless you have quite a bit of space a u-turn could be dangerous or expensive and is rarely usefull.. (most sportsbikes wouldn't be able to uturn in a tight space anyways! but my transalp was piece of pish, used it allot more then)
I guess more than anything its a mesure of low speed controll Confused
colin1
Captain Safety
PostPosted: 21:48 - 08 Mar 2006    Post subject: Reply with quote
i did a u turn today in heavy traffic. saw the gap and knew i could make it but it didnt leave much margin for error. Probably not very sensible but it felt good. turning circle on my yp250 is pretty good. i wdnt try it on anything that wasnt a big dirt bike or big scooter. anything less than a 250 wdnt have pulled away quickly enough for me to avoid being rear ended when i completed the u turn in fornt of the oncoming car
fuzz
PostPosted: 11:31 - 09 Mar 2006    Post subject: Reply with quote
If you're on a 500, you can use your mirror for the 2nd observation. It should keep you more balanced before you turn. The thinking is that the mirrors on the larger bike give you a better view. You can also use your mirror before you brake, speed up etc. instead of a look over your shoulder.
Misc
PostPosted: 17:18 - 09 Mar 2006    Post subject: Reply with quote
I was taught it would be a straight fail because if you put a foot down this shows you have no control.
krebsy
PostPosted: 17:44 - 09 Mar 2006    Post subject: Hmm. Reply with quote
From what I can remember I did:
Rear observation
Move off
Rear Observation
U-Turn
Signal left
Left Observation
Pull in
Stop
Cancel indicator.
If it's not clear then you don't do the move. I was taught that you check when you move away and again just before you do the U. That way you are showing you are moving off correctly and are also hecking before changing direction. There's no need to do a rear obsservation once the bike is pointing the other way as you wouldn't have done the move if there was traffic coming. You need to pull in correctly as per the stopping procedure once the U has been done.
Set off correctly. (1st rear check)
check behind and U-turn. (2nd Rear check)
Pull in correctly. (L-Hand Lifesaver.)
Delvard, the 2nd method you describe is what I was taught as you have to do the 2nd check to be sure it is safe to turn. If you check, move off and then U-turn without checking again then they can fail you for incorrect rear obs. you changed direction without making sure it was safe to do so.
Mind you, when you do the U-turn you should be looking in the direction you want the bike to end up in after all, so when you are about to turn you can look behind you as the 2nd check and keep looking in that direction as you whip the bike round.
One thing I learned for the U turn is that the bike won't fall over as long as you give it some throttle. don't try to do a "too slow" U-turn as it just sets the bike up for a fall and your foot will go down if you think the bike is dropping. If it feels like it is going to fall then crane your head round further, make sure you are looking back down the road and give it some juice. It'll be round before you know it.
When practicing before the test, the other trainee was doing slow and shaky U's on the playground and I was going twice as fast and turning the bike around inside his loop because I was leaning it right over, giving it some juice and looking at where I wanted the bike to be, not at where the front wheel was currently going...
Lots of Ramble there, dissect at your leasure... Smile
K.
1280 x 1024.
Annabella
Like a person, only smaller
PostPosted: 10:57 - 10 Mar 2006    Post subject: Reply with quote
I failed my first test by dabbing my foot down just before I completed the U-Turn - more out of panic than anything else as it was a busy narrow lane.
I got no minors, just that one major. I think I failed because I knew I had ridden well up until that point (near the end of the test). I actually said the the examiner when I pulled up, "I've failed haven't I?", his reply was "You hadn't, but you have now!"
So, in hindsight, best thing to do is to ignore putting your foot down and not to panic...
Avast! Pirates ahoy!
I did Cadwell! Very Happy
The last post was made 20 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.73 - MySQL Queries: 13 - Page Size: 111.73 Kb
