| dapthechap |
 dapthechap Borekit Bruiser
| bidman |
 bidman Crazy Courier
| dapthechap |
| -Savage- |
 -Savage- World Chat Champion
 Posted: 18:01 - 29 Nov 2005 Post subject: |
hey dap, my cbr wont start either, the starter turns fine, but she wont fire. As we speak, im taking the sparkplugs out to see if thats the problem, have you checked yours? ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
| dapthechap |
| dapthechap |
| bidman |
 Posted: 18:07 - 29 Nov 2005 Post subject: |
First check all the plugs make sure they are all firing and in good condition looking for a browny colour . Then check to see that the battery is holding its charge, charge it up then leave it for a day or two and test it to see if it has gone down, then when the battery is being charged it is being charged at 2.0Amps per hour, if its more than this then your over charging your battery and it has probably ruined the cells in your current battery, if this is the case make sure your regulator/rectifier is still working and replace the battery.
I have had a few honda regulator/rectifier's play up and over charge batteries so i wouldn't be supprised if this is your problem
Hope this helps, and let me know how it goes, Dan ____________________ Don't ride it, RAG IT!!
| -Savage- |
 Posted: 18:08 - 29 Nov 2005 Post subject: |
look at the contacts to see if they are covered in soot, if they are clean them with a wire brush. have a look in the sticky thread in the workshop section for your bike maintenance manual, thats what im using. it has fault diagnosis and easy to follow steps.
could be just a loose wire in the ignition wiring, i know mine had that, if you turned the handle bars, the ignition would cut out.
explain exactly what happen when it wont start, in as much detail as you can,
eg, i put the key in, i turn the key, the lights on the dash come on, i press the starter button,,,,etc ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
| dapthechap |
| bidman |
| dapthechap |
| bidman |
 Posted: 18:26 - 29 Nov 2005 Post subject: |
Yeah it helps not to have a lot of dust around whilst cleaning the carbs but I do it all the time in my garage, as long as you make sure all the jets are clear and that your idling speed is as it should be, if they are you should be getting enough fuel through to start it  ____________________ Don't ride it, RAG IT!! |
| fazed |
 fazed Korn is my hero!
| dapthechap |
| bidman |
 Posted: 12:24 - 30 Nov 2005 Post subject: |
Yes, do what kickstart suggested as this would show that it is probably your reg/rectifier at fault  ____________________ Don't ride it, RAG IT!! |
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful? |
