Replacing the fork oil.
shammon
PostPosted: 21:58 - 29 Nov 2005    Post subject: Replacing the fork oil. Reply with quote
Will putting in new fork oil into the front shocks make them more responsive and better, And ho do you tell if your forks need replaced ? this talk of pitting? what is that and where on the forks if found will it fail an mot.
Thanks. Neutral
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
loply
PostPosted: 22:59 - 29 Nov 2005    Post subject: Reply with quote
"Pitting" means small holes/scrapes/rust on the fork legs (on the thin/inner bit). Theyre a problem because theyll allow oil to leak out of the forks through them.
Forks dont need to be replaced, only the small seals inside them.
Putting new fork oil in is only neccessary if hte old ones are running low/leaking (which also means new fork seals are required).
If the forks are low on oil the suspension will be springy and light and imprecise.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Ichy
PostPosted: 23:11 - 29 Nov 2005    Post subject: Reply with quote
Changing the fork oil can improve the feel of the front end especially if the bike is more than a couple of years old.
The last post was made 20 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 35.25 Kb
