1 Litre car + Bike Trailer
ash t
PostPosted: 23:32 - 29 Nov 2005    Post subject: 1 Litre car + Bike Trailer Reply with quote
Just a simple question.
Im getting a car next month, and was just wondering if a 1 Litre car would be ok for towing a trailer loaded up with 1, and sometimes 2 bikes.
Sorry for a boring, bone question.
Ash Thumbs Up
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
Bendy
Mrs Sensible
PostPosted: 23:36 - 29 Nov 2005    Post subject: Reply with quote
Maybe one if it's a light trailer and a light bike. Wouldn't try two.
garry
PostPosted: 23:45 - 29 Nov 2005    Post subject: towin Reply with quote
all depends on the car ...
what is it ?
and pullin one bike , pw50 or st1100 ?
so long so long so long and thanks for all the fish !
scol1
PostPosted: 23:45 - 29 Nov 2005    Post subject: Reply with quote
Put the car on the trailer and tow it with the bike Laughing
Seriously though,you should check what the maximum towing weight is for your car,and it makes a big difference if the trailer is 'unbraked' or not........it'll tell you the info you need in your handbook.
J.
CB1300,a proper bike!
ash t
PostPosted: 23:49 - 29 Nov 2005    Post subject: Reply with quote
Not sure what car. Not bought it yet. Probably a Corsa or a Fiesta.
It will be carrying my CBR400, and maybe sometimes another CBR400 at the same time.
Gazdaman
I did a trackday!!!
PostPosted: 23:57 - 29 Nov 2005    Post subject: Reply with quote
I wouldn't.
I drive a 1.2 corsa, and that's damn gutless at the best of times. 16v model aswell.
I would use my corsa to tow my TZR250 on a trailer. But I certainly wouldn't take 2 CBR400s.
Fill the car with 5 people, and see how it goes. You'll soon see why you don't want a trailer.
Gaz
Sparks!
Sir Tart-a-lot
PostPosted: 23:59 - 29 Nov 2005    Post subject: Reply with quote
1 bike + trailer on my 2ltr turbo diesel peugeot slows it down a bit, wouldnt fancy trying 2 sports bikes on a smaller 1.2 non turbo car Shocked would happily tow both with my trusty peugeot though Razz
Gazdaman
I did a trackday!!!
PostPosted: 00:02 - 30 Nov 2005    Post subject: Reply with quote
With 5 people in my corsa you can actually hear the clutch cry as you try to pull away...
Gaz
PostPosted: 00:15 - 30 Nov 2005    Post subject: Reply with quote
Looking here and it seems the max towing weight for a 1L Corsa is 450kg for an unbraked trailer. However, even if legal I would really expect it to barely move.
Mind you, looking at that the new ones weigh 1400kg. That is a hideous amount for a poxy little 60hp box. Go back to the early 1970s and an early Alfasud had 63hp from an 1186 engine yet it only tipped the scales at 862kg. My little car manages to weigh about 1200kg, and that is with 4wd.
extreme3d
PostPosted: 00:26 - 30 Nov 2005    Post subject: Reply with quote
Don't confuse towing with carrying... basic physics, you can tow a lot more than u can carry....
Towing limits are nothing to do with power but are based on the weight of the vehicle.
A good example of towing is on any road - a lorry Very Happy
A good example of inefficient loading is the space shuttle. By towing a shuttle up to the upper atmosphere behind a conventional aircraft and then letting it do the final hurdle itself you can get it into space with very little fuel (and therefore power) than compared with it's usual piggyback booster affair.
(It's lofted with the booster though as its much much easier to get the craft into a correctly position and calculated orbit when fully laiden with a 6 tonne satellite. You can also get it into higher orbits. Wink )
M1ke
Ped Boi
PostPosted: 03:40 - 30 Nov 2005    Post subject: Reply with quote
My 1.8 diesel Fiesta has 59bhp and manages to tow two 400cc bikes without too much hassle, it sits at 70mph ok (on flat) and the brakes work fine. Its not fast pulling away but its bareable. I wouldn't say a 1.1-1.2 with similar power would be much different.
california_rookie
PostPosted: 05:17 - 30 Nov 2005    Post subject: Reply with quote
An open trailer with a sub-500lb bike should be alright.
Worst case scenario.
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Davo
Davo To The Rescue!
PostPosted: 05:19 - 30 Nov 2005    Post subject: Reply with quote
Your fiesta will be heavier and the engine will develop it's torque much lower in the rev range though.
quacker_boy
Cuddle Bitch
PostPosted: 05:35 - 30 Nov 2005    Post subject: Reply with quote
i got an idea ash...buy a bigger car and as a couple of people have already said get a diesel mate.
their engines have got a lot more torque especially at lower revs so they'll be fine when pulling away...also diesel engines are more economical.
colin1
Captain Safety
PostPosted: 09:12 - 30 Nov 2005    Post subject: Reply with quote
i agree with quacker
PostPosted: 09:15 - 30 Nov 2005    Post subject: Reply with quote
Agree if you want something just for towing.
On the other hand if you want something fun to drive then avoid them like the plague.
quacker_boy
Cuddle Bitch
PostPosted: 09:35 - 30 Nov 2005    Post subject: Reply with quote
touche Laughing
if you're planning on thrashing it about like a rag doll, get a petrol you'll have a lot more fun. but diesel's are a lot more suited to being workhorses
Knowlsey
PostPosted: 12:07 - 30 Nov 2005    Post subject: Reply with quote
i've got a 1.2 corsa, and i have pulled a small trailer filled to the brim with crap, if the trailer is light enough and you are only towing one bike there should not be a problem, even with kerbside weight ratio
ZRX61
Victor Meldrew
PostPosted: 16:54 - 30 Nov 2005    Post subject: Reply with quote
LOL! I think the starter motor on my pick-up puts out more power than that
lilredmachine
PostPosted: 16:58 - 30 Nov 2005    Post subject: Reply with quote
a decent weiand blower takes more than that just to turn.
Rob W
PostPosted: 17:02 - 30 Nov 2005    Post subject: Reply with quote
LMFAO, quality!
ZRX61
Victor Meldrew
PostPosted: 17:06 - 30 Nov 2005    Post subject: Reply with quote
Thumbs Up lmfao
Bendy
Mrs Sensible
PostPosted: 17:07 - 30 Nov 2005    Post subject: Reply with quote
My diesel Laguna only makes about 75bhp and it tows really well, the key being that its a fairly big heavy car that overpowers the big heavy trailer. Tows more comfortably than my more powerful Golf did.
Having pulled heavy trailers with smaller cars, it's sometimes not fun. You gotta think about what happens if the trailer wants to go in a different direction to the car - which is going to win.
Minky_monkey
PostPosted: 18:17 - 30 Nov 2005    Post subject: Reply with quote
Ash, how long have you had your licence mate?
Check up on this from the DVLA as you may be exceeding your licence allowance for Maximum Authorised Mass and in certain cicumstances, you may need to take another test.
https://www.dvla.gov.uk/drivers/dl_towing_trailers.htm#2.%20%20CAR%20DRIVING%20LICENCE%20FIRST%20OBTAINED%20SINCE%201%20JANUARY%201997
mrchips
PostPosted: 20:02 - 30 Nov 2005    Post subject: Reply with quote
My 60bhp diesel Orion pulls handy enough.
Northern Irish? www.nibikers.com
The last post was made 20 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 129.17 Kb
