Suzuki RG125F 1994 OIL LEAK
faith183uk
PostPosted: 10:36 - 30 Nov 2005    Post subject: Suzuki RG125F 1994 OIL LEAK Reply with quote
Hi everybody, hope someone can help me with this.
Ive bought a RG125F for £225. The bike is mint apart from it was hard to start and smoked quite a lot. The last owner had have a new barrel/ piston etc fitted and run it in.
The smoking was easily sorted as the Oil pump has set way to high, i assume to aid the running in of the new piston and barrel. I have adjusted it and good stuff the smoke is as normal for a 2 stroke.
The problem i have now is i seem to have a leak coming from the oil pump. It only leaks when on the side stand, or maybe just leaks faster so its more noticable.
The only thing i can think of and see thats a little worn is the small oil pump bleeding screw, i was to replace it but everywhere i try tells me they dont sell just the bleed screw by itself only the whole oil pump??
Does anyone know where i can get said screw and will an oil pump off a 1992 RG125 Wolf fit the RGF. As far as i know they are the same bike just without the front fairing and a different headlight.
Any help would be appreciated
Many Thanks in advance
faith183uk
PostPosted: 10:43 - 30 Nov 2005    Post subject: Reply with quote
Oh and heres a picture of the RG125F bought for £225
PostPosted: 12:14 - 30 Nov 2005    Post subject: Reply with quote
Firstly, I thought the faired one had a banana swinging arm while the Wolf version had the straight swinging arm yours is fitted with. Might be that someone has already been swapping bits around.
Not sure on the exact design of the pump and the bleed screw but I would expect it to just be a normal small bolt. However I would expect it to have some kind of sealing washer fitted. Could just be it needs a new fibre washer.
faith183uk
PostPosted: 17:42 - 30 Nov 2005    Post subject: Reply with quote
Thanks Keith, Theres not one there so ill put one one and see if it helps.
The swingarm is banana shaped on the exhaust side, and straight on the chain/sprocket side.
Not my bike but an example of the swing arm.
bidman
PostPosted: 18:19 - 30 Nov 2005    Post subject: Reply with quote
Also get hold of some gasket sealent to help make sure its all nice and sealed, Thumbs Up Dan
Don't ride it, RAG IT!!
PostPosted: 20:30 - 30 Nov 2005    Post subject: Reply with quote
Thought the banana arms on those were bigger on the left. Oh well.
Not sure I would want to use instand gasket even there. Too much chance of a bit getting into the pump when you fit it and blocking the pipes (only a low pressure pump).
The last post was made 20 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 48.15 Kb
