dodgy reg/rec??? advice needed
mirax
PostPosted: 22:26 - 30 Nov 2005    Post subject: dodgy reg/rec??? advice needed Reply with quote
After a recent post i made regarding my head lights playing up. i.e. sometimes my headlights would go suddenly bright for a couple of seconds then back to normal on ocastions this can be like once or twice on a 10 mile journey. today i checked the wires plugging into the reg/rec and they seem fine i also checked the 3 yellow wires from the alternator which seem fine aswell, i checked the voltage on the battery. the results are as follows
bike off 12.63v
bike off lights on 11.43
bike idling 14.43 this was a gradual incress from 12.63v
bike held at a revs of 5000rpm was 14.12v then once it suddenly jumped to 15.64 in a split second
is that sudden jump a sign of it on its way out?
Bezzer
PostPosted: 23:15 - 30 Nov 2005    Post subject: Reply with quote
Take it it's a Honda?? have you got the manual for it, it will show the expected outputs in there. Strange you should see a higher figure idling figure than at 50000rpm, the 15.63 blip you got is around the max for a lot of Hondas, they usually say max of 15.5 at 5000rpm. I'd take it that the reg/rec is on it's way out, the voltage should rise fairly smoothly when you increase the revs, probably better to get one sooner rather than later, if it does stick open it can cause a lot of expensive electrical damage.
NC30UK
PostPosted: 23:44 - 30 Nov 2005    Post subject: Reply with quote
When the reg/recs go they do one of 2 things, they either overcharge the battery and melt all the connections (most common) or they stop charging anything.
Regular inspection or the connections is the only way to tell if it's on the way out.
The newer more reliable ones can be picked up for about £30 if you know where to look Wink
PostPosted: 23:47 - 30 Nov 2005    Post subject: Reply with quote
I don't understand why Honda have so many problems with their reg/rec units. Back in the late 70's they made the most reliable and effective reg/rec units on the market, as fitted to the 250 superdream.
They still are among the best ones too, you can stick them on anything with a 12v, magnetic alternator and they just work. I have no idea whatsoever why they stopped using them.
If I had a dodgy reg/rec on any of my bikes, I would fit a superdream one rather than getting an original replacement (except on my Jawa, it has a field coil alternator which works in a different way).
The last post was made 20 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 40.48 Kb
