 Philious Brolly Dolly
 Posted: 17:41 - 30 Nov 2005 Post subject: Suzuki AE50 Electrical Problem |
Ok guys after having the mtx stolen and now being without a bike 4 a couple of months i've decided 2 pull my finger out and see what i can do with the AE50 moped
Basically i had it put it into storage a few months ago as i bought the mtx and couldnt find a buyer, after the mtx was stolen i decided 2 take the ped out of storage and start using it again
after 10mins riding it i noticed some rather strange things happening. Both brakes front and back were sticking... but it felt as if they weren't working efficiently.
Then when i indicated for a junction i noticed my indicator light on the dash wasnt working, then the indicator itself... subsecquently every bulb on the sodding bike has blown.
What bemuses me is how theres a fuse on one of the leads from the battery and its still intact surely this should have blown 2 protect the bulbs etc?
I havent even got around to getting it tested.
What possible causes cud make this happen?
Come on i need some insperation here..... if anyone has anything constructive or any advice i'd be grateful, also b4 u say sell it or bin im not in the financial situation 2 buy a new one or get my test (part-timer) but i am looking 2 change the situation, i miss being mobile, especially in this weather.
Thanks in advance  ____________________ Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09 |
 Posted: 14:15 - 01 Dec 2005 Post subject: |
Almost certainly your voltage regulator has gone bye-bye. It is a black box. You would need to measure the voltage across the battery terminals to check this. If it is a 12v system, anything much above 15V while the engine is revved up indicates a problem with the regulator.
Not sure of the levels on a 6V bike but I would say probably over 8v or so would indicate a problem.
The voltage regulator is a 'black box'. If it is broken, you need to replace it.
Just something to note, some very basic bikes don't have a voltage regulator and use the battery itself to 'damp down' the voltage in the loom. In this case, a seriously fucked battery (like plates welded together) could cause the symptoms you describe. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
